Potential Energy Function problem ()
The potential-energy function U(x, y) = a*(1/x² + 1/y²) describes a conservative force acting on an object in the xy-plane. To find the force F, the partial derivatives with respect to x and y are taken, resulting in F = [(2a)/(x³)]i + [(2a)/(y³)]j. However, the computer system indicates that the answer should not include the variable "a" and suggests using "alpha" instead. This discrepancy highlights the importance of correctly identifying variables in the problem. The discussion emphasizes the challenges of computer-based grading systems in interpreting mathematical expressions accurately.
ccsmarty
An object moving in the xy-plane is acted on by a conservative force described by the potential-energy function U(x, y)= a*(1 / x^{2}+1 / y^{2}), where a is a positive constant. Derive an expression for the force F expressed in terms of the unit vectors i and j.
Gradient vectors, Partial derivatives
I know I have to take the partial derivatives w.r.t. "x" and "y". But when I did that I came up with F = [(2a)/(x^3)]i + [(2a)/(y^3)]j. But the computer says: "The correct answer does not depend on the variable: a." But if I take the a out, it tells me that: "The correct answer involves the variable alpha, which was not part of your answer."
Any ideas??
Thanks in advance
rename "a" as "alpha" ... maybe "2a" ... ?
^ bump
You aren't being ignored: I think we just aren't sure what the computer doesn't like...
It looks like you've evaluated the gradient of U and expressed the components of F correctly. The issue seems to be what "a" was in the potential function you posted. Is that supposed to be \alpha? Computer entry systems are notoriously finicky. (Curse them!)
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
