Potential energy of a displaced mass on a spring
The discussion focuses on calculating the potential energy U(x) stored in a spring with a non-linear restoring force, given by F(x) = (-k1x) + (k2x^2). The user attempts to integrate this force to find the potential energy, resulting in ΔU = -k1(½x0^2) + k2(⅓x0^3). However, there is confusion regarding the application of the standard potential energy formula U = ½kx^2, which is only valid for linear springs. Participants suggest refining the approach to ensure consistency in the equations used, particularly emphasizing that ΔU should reflect a difference between two states. The conversation highlights the importance of correctly interpreting the equations for potential energy in the context of non-linear spring behavior.
AsadaShino92
A spring of negligible mass exerts a restoring force on a point mass M given by F(x)= (-k1x)+(k2x^2) where k1 and k2 >0. Calculate the potential energy U(x) stored in the spring for a displacement x. Take U=0 at x=0.
ΔU=∫F(x)dx
U=½kx^2
Using the equation above I tried to find the potential energy of the spring after it has been displaced by some distance x. I integrated F(x) from x=0 to some displacement x=x0.
ΔU=∫(-k1x)+(k2x^2)dx
ΔU=-k1½x0^2+k2⅓x0^3
Is this the right way in finding the potential energy?
Almost. Basically you are going to refine your second relevant equation. So if ##k_2 = 0## you should find it back. Do you ?
[edit] hint: what about the discrepancy between 1st and 2nd relevant equation ?
So then I can use the fact that ΔU= Uf-Ui= ½kxf^2-½kxi^2. Where f is final and i is initial?
If this is correct, then xi=0 and that term drops out. Then I would be left with ½kxf^2 = -k1½x0^2+k2⅓x0^3
AsadaShino92 said:
U=½kx^2
No. As BvU was hinting, that equation is only valid if F(x)=-kx.
No, for the reason given above.
AsadaShino92 said:
ΔU=-k1½x0^2+k2⅓x0^3
Yes, except that you have a Δ on the left, implying a difference between two different states. On the right, you have assumed that one of those states is x=0. Try to write it consistently.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 17 ·
