Potential Energy of the Atmosphere
Using the hydrostatic relationship to express density (rho) and height (z) in terms of pressure (p) may not be effective for solving the question. Familiarity with the ideal gas law is suggested as a more useful approach. The discussion emphasizes the importance of providing more context and effort in queries, as per forum guidelines. Participants are encouraged to engage more deeply with the problem rather than simply stating difficulties. Overall, a more thorough understanding of relevant principles is necessary for progress.
boopdebeep
Thread moved from the technical forums to the schoolwork forums
Summary:: I have been trying to do this question for a while using the hydrostatic relationship to put rho and z in terms of p, however, I can not seem to end up with an answer. Can anyone suggest where to start.
The question is as follows:
Helli @boopdebeep ,
:welcome: ##\qquad# !​
might not be so useful. Do you know about the ideal gas law ?
btw: PF rules ask a bit more from you than just 'can't find an answer' ... :frown:
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
