Potential on the axis of a uniformly charged ring
The discussion centers on calculating the electric potential due to a uniformly charged ring. The potential is derived by integrating the contributions from each element of the ring, leading to the formula V = (λ/(2ε₀))(R/√(z²+R²)). There is emphasis on the importance of using the correct path for integration, as the electric field's circulation around the ring is zero. The initial approach was critiqued for not considering the field at points on the ring, which is essential for accurate potential calculation. Ultimately, the derived formula aligns with the expected result for the potential at a point along the axis of the charged ring.
Guillem_dlc
We have a uniformly charged ring of radius ##R## with a linear charge density ##\lambda##. Determine the potential at a point on its axis at a distance ##z## from the plane of the ring.
Answer: ##V=\dfrac{\lambda}{2\varepsilon_0}\dfrac{R}{\sqrt{z^2+R^2}}##
##V_z=\int E\cdot dl##
We know that
$$V_Z=\int_{\textrm{ring}} E\cdot dl$$
We therefore consider ##E=\dfrac{\lambda}{2\pi \varepsilon_0}\cdot \dfrac1r##. Then,
$$V_Z=\int_{\textrm{ring}} \dfrac{\lambda}{2\pi \varepsilon_0}\cdot \dfrac1r\, dl = \dfrac{\lambda}{2\pi \varepsilon_0}\dfrac1r \int_{\textrm{ring}}dl=$$
$$=\dfrac{\lambda}{\cancel{2\pi} \varepsilon_0}\dfrac1r \cancel{2\pi} R=\dfrac{\lambda}{\varepsilon_0}\cdot \dfrac{R}{r}=\dfrac{\lambda}{\varepsilon_0}\dfrac{R}{\sqrt{z^2+R^2}},$$
where ##r=\sqrt{z^2+R^2}##.
I have done this.
It's just an accident that your answer is close to the right one. To calculate the circulation of the electric field around the ring you will need the field at points on the ring not somewhere on the axis. This field is not directed tangential to the path, And anyway, this integral around the ring (closed path) should be zero. so it will be useless.
You need to calculate the potential by integrating the contributions of each element of the ring to the potential to the given point on the axis. Similar to what you did for the electric field of the ring.
Or, you could use the definitionn of potential based on the integral of the electric field but then you need to integrate from the given pont to infinity and use the right path (and right formula for the field).
Now I had done this and I would say it's fine. We have a charged ring:
$$V=\int_{\textrm{ring}} dV=\int_{\textrm{ring}} k\dfrac{dq}{r}=\int_{\textrm{ring}} k\dfrac{\lambda dl}{r}=k\dfrac{\lambda}{r}\int_{2\pi R}dl=$$
$$=k\dfrac{\lambda}{r}2\pi R=\dfrac{1}{4\pi \varepsilon_0}\dfrac{\lambda}{r}2\pi R=\dfrac{\lambda}{2\varepsilon_0}\dfrac{R}{\sqrt{z^2+R^2}}$$
It looks like you got the right answer. Doesn't it?
Likes Guillem_dlc
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
