Powder coating: way to add more positive charge?
Powder coating at home involves using negatively charged parts and positively charged powder for effective adhesion. Concerns were raised about enhancing the positive charge from inexpensive powder coating guns, particularly those from Harbor Freight. It was suggested that upgrading the cascade in the gun could increase voltage output, potentially improving performance. Additionally, practical challenges such as baking the coated parts at the required temperatures in a home setting were highlighted. Overall, achieving effective powder coating at home requires careful consideration of equipment and techniques.
stryped
TL;DR
Powder coating
I am thinking of powder coating at home. I know the part to be coated is negatively charged because it is grounded. I assume the powder is positively charged by the gun. I wonder if there is a way to add more positive charge cheaply to an inexpensive gun like the one at harbor freight? I think this is one of the drawbacks of a cheaper made gun. Could some sort of static charge be added?
I use to work in a powder coat factory, spray on powder is thermoset plastic. Hot oven melts plastic to clean metal parts. You can order powder any bake temperature you like. I think the lowest bake temperature is about 350°f. We used 540°f power. Metal parts are electrically charged + & - to make powder attracted to parts. Call PPG they sell powder, they will mail you 1 lb free samples. House is none conductive how will you make powder stick and how will you bake your house in an oven? Heat gun will take years.
stryped said:
TL;DR Summary: Powder coating
The cascade is located in the barrel of the pistol. That will determine the voltage you get out. Simply install a more powerful one, up to 140kV.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
  • · Replies 58 ·
  • · Replies 36 ·
