Power delivered to wheels of car with constant air resistance
  • Thread starter Thread starter I_Try_Math
    Car Power Wheels
The discussion centers around the power required by a car to overcome air resistance at different speeds. At 15 m/s, the car needs 20 hp to counteract air resistance, but when accelerating to 30 m/s, the total power requirement increases to 40 hp due to the need for additional power to maintain the higher speed. The participants explore how the formula P=Fv applies, emphasizing that while air resistance remains constant, the work done increases with speed. They also consider the implications of gear selection on engine torque and power delivery. Overall, the key takeaway is that maintaining higher speeds necessitates greater power output despite constant air resistance.
I_Try_Math
Suppose that the air resistance a car encounters is independent of its speed. When the car travels at 15 m/s, its engine delivers 20 hp to its wheels. (a) What is the power delivered to the wheels when the car travels at 30 m/s? (b) How much energy does the car use in covering 10 km at 15 m/s? At 30 m/s? Assume that the engine is 25% efficient. (c) Answer the same questions if the force of air resistance is proportional to the speed of the automobile. (d) What do these results, plus your experience with gasoline consumption, tell you about air resistance?
##KE=\frac 1 2 mv^2##
##P=\frac W t##
For part (a) the answer key is saying it's 40 hp. I'm having trouble understanding this. So the car accelerates to 15 m/s, then it stays at that velocity of 15 m/s, needing only 20 hp power to overcome the work done by air resistance. Supposing the car then accelerates to 30 m/s and stays at that velocity and given that air resistant is constant in this problem, wouldn't the engine only need that same 20 hp to overcome air resistance and keep the car at 30 m/s?
How far does the car travel in one second at 15 m/s?
How far does the car travel in one second at 30 m/s?
Say that the force of air resistance is ##F##.
How much work is done by air resistance against the car as it covers the distance for 15 m/s?
How much work is done by air resistance against the car as it covers the distance for 30 m/s?
Or...
Is the engine in first gear or second gear for the two situations? What does that mean for how much torque the engine has to provide in the two situations?
##P=Fv##, apply this formula for the force of air resistance which is constant independent of speed and for the velocities ##v_1=15,v_2=30##.
Or...
Ah that makes it clear as day, thanks.
