Practice Problem about the Energy of a Pendulum
  • Thread starter Thread starter stephy
    Energy Pendulum
The discussion centers on a practice problem regarding the energy of a pendulum, with initial answers provided as 7.35 m/s for speed and 216.09 m/s² for acceleration. Participants emphasize the importance of showing work and reasoning behind the calculations to facilitate better assistance. There is a suggestion to consider energy principles for solving the problem. The conversation highlights the need for detailed explanations rather than just final answers. Overall, the focus is on understanding the underlying concepts of pendulum energy.
stephy
A small sphere of mass m is fastened to a weightless string of length 0.5m to form a pendulum. The pendulum is swinging so as to make a maximum angle of 60 degrees with the vertical.
a) What is the velocity of the sphere when it passes through the vertical position?
b) What is the instantaneous acceleration when the pendulum is at its maximum deflection?
a) v=sqrt(L*g*sine(thet)*tan(thet)
b) ac= v^2/r
Answer:
a) 7.35 m/s
b) 216.09 m/s^2
*Is this correct?
It would be easier to offer you help if you offer a bit more detail for your reasoning.
In both of the cases a) and b), what is your argumentation behind the expressions?
stephy said:
*Is this correct?
I suggest you read the forum rules, one of which is that you are required to show work (not just answers).
No working out offered by me (yet), but I would look at energy considerations for the first part.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
