Pragmatism Morphed into a Reasoning System
  • Thread starter Les Sleeth
  • Tags
    System
In summary, the conversation discusses the use of a reasoning system in philosophy and suggests that a variation of pragmatism may be the most suitable for philosophical debates. The concept of a "reasoning system" is defined as a collection of components that serve the overall reasoning function, with three levels - foundational, advanced, and vanguard. The foundational components include information, logic, and integrity, while the advanced components are comprehensiveness and depth. The vanguard component is inference, which is dependent on the other components being done well. Pragmatism is described as a uniquely American development that emphasizes the importance of something working in order for it to be considered true. The conversation also touches on the idea of empiricism and the approach of using
  • #36
Originally posted by Lifegazer
No I'm not. I'm saying that it cannot be disproven by logic,
So what? Materialism cannot be disproved by logic either. For that matter, neither can the Easter bunny, Santa Claus, or invisible fairies dancing around your head.
since my logic matches known laws of science. In other words, you've already tested my hypothesis, because it matches all-known laws - which have already been tested.
My arguments are founded upon laws and reason. Via the direct-experience of sensation. When you say that there is no way to test it by way of experience, you ignore the fact that my argument is founded upon the experiences we are all having now. I have not based my arguments upon anything but experience. And that's a fact.
No, it is not.
I've had quite enough of this nonsense. It has been explained to you over and over that your ideas do not "match" the laws of science, and that tests of scientific laws are not confirmations of your ideas.
Firstly, can Zeus explain his own origin? I.e., can the philosophy "of Zeus" explain *everything*, rationally? If it cannot, then Zeus is of God. Not God himself.
"The Mind" cannot explain its own origin either, and neither can it explain everything rationally.
In fact, it cannot explain anything rationally.
The point is obvious. Reason can rip-apart specific concepts, until those concepts have explained everything, including themselves.
And when these concepts cannot explain such things, then these concepts are all but worthless.
No. Reason cannot test premises; only observation can do that. That is the whole point of this thread.
You have reason to invalidate crackpot-theories. And yet you sit there saying you cannot disprove it because you cannot experience it. That's incorrect LWS.
No, he is right. Reason can only tell you if a crackpot theory is internally inconsistent. It cannot tell you if the premises or conclusion are wrong.
Only observation can do that.
From itself. Reason is a system which seeks to define the relative-world in relation to absolute-scales of existence. Reason stretches towards absolute-concepts. The mind unquestionably-knows about absolute-concepts of existence.
No, reason has nothing to do with existence.
The laws of logic are prescriptive laws pertaining to inferences. It has only to do with form, and very little to do with the content of statements.
Hence, there is no reason whatsoever why an argument founded upon reason, cannot take us to the absolute-source of existence.
You cannot discard this notion by repeating that you've had no experience of such things, and so cannot disprove them. Because you have the essence of all knowledge to disprove of such thoughts. You have reason itself. And if you are going to be sincere unto your own earlier thoughts, then you should listen to what I'm trying to say to you.
Given that you are wrong about what reason is, this is totally off base.
LW Sleeth correctly observed something about you. He said that you are mixing up notions of inductive and deductive logic into some kind of "superlogic". Specifically, to your mind it seems that logic has the certainty of deductive validity not only for inferrential forms, but also for testing of premises, and that is false.
This "superlogic" does not exist except as a figment of your imagination, just like "The Mind". If you come up with a third one, then your religion can have its own Trinity.
You are a materialist LWS. To what degree, I do not know. But I do know that logic does not allow for a bias towards experience as the basis of all knowledge.
"Logic" doesn't have anything at all to say on the matter. In fact, if all we use is logic, we have the opposite problem: any and everything you can imagine becomes a candidate for a theory of reality.
That is another main point of this thread.
Logic was/is the true source of all knowledge.
Wrong: Logic does not supply knowledge at all.
Well my philosophy 'works' too. It explains everything (because it embraces science), and it also has profound repercussions for humanity.
This is false. Your ideas contradict science in that you must twist scientific theories around to suit your biased conclusion. We have explained this to you many, many times.
  • #37
True logic cannot take you to a materialistic-position. We both know that a "leap-of-faith" is required to state that there is an existence beyond sensation. As such, logic cannot advocate any such stance. And I did in fact produce an argument to challenge the notion of external-reality. Reason can challenge any concept.
It takes blind-faith to believe in all of the above. For reason simply cannot accept such concepts as being true. Upon what possible basis could it? But this is the philosophy forum Tom. Not the religion forum.
No, it is not.
Is my mind-hypothesis compatible with the base indeterminancy of QM? Is my mind-hypothesis compatible with 'relativity'? Is my mind-hypothesis compatible with other known laws? Does my mind-hypothesis challenge the equations of any known laws?
Existence is fundamentally eternal. It's very easy to prove this. Something cannot come from absolute-zilch. Therefore, something has always existed.
"The Mind" has no origin. And it has no end.
Such as?
The whole point of the thread is to assert that only sensations can confirm that a process of reasoning is correct? Then what price mathematics, with her 'zeroes' and 'infinities'? Can you show me a tangible-sensation whereby I can see such things for myself?
Reason is apart from sensation. And it makes sense of it. It also makes sense of concepts which exist beyond sensation.
  • #38
I still think you haven't understood the idea of proof.
Some reason does, but some reason reaches toward garbage. It almost sounds like you consider reason just short of divinity. Like Papal infallibility, you seem to believe reason can never fail. Reason is only a mental discipline.
That is too much . . . look at what thought is! It is an abstraction that is not even as an accurate a representation of reality as a TV image is. How is it going to take one to the absolute source? It is just like those people who argue endlessly about what is the proper religious "beliefs." In the end, how much power does a belief have? With belief alone, one can't believe oneself into anything except delusion. Sure, combined with a plan, and then action, a belief can be motivating, but to say it can be so powerful as to get one into heaven or send one to hell ignores the nature of belief.
Similarly, you are imparting to thought power it doesn't exhibit. If thought had that power, we wouldn't need our bodies or appliances or construction machinery . . . we could just will it all to happen without a physical medium.
You cannot discard this notion by repeating that you've had no experience of such things, and so cannot disprove them. Because you have the essence of all knowledge to disprove of such thoughts. You have reason itself.[/I]
First of all, I am not trying to discard your notion of Mind. I am saying that so far you haven't done what it takes to prove it. Secondly, I think you already know that experience is the basis of knowing.
For example, if you were going to have heart surgery done, who would be your first choice? A surgeon with lots of successes under his/her belt, or a great theoritician who has never operated? When you are hungry, will a concept of food satisfy your hunger or do you need the experience of food?
Experience is where you find reality, mind is where you work out what experiences to pursue.
And if you are going to be sincere unto your own earlier thoughts, then you should listen to what I'm trying to say to you. You are a materialist LWS. To what degree, I do not know. But I do know that logic does not allow for a bias towards experience as the basis of all knowledge. Logic was/is the true source of all knowledge. The sensations don't know a thing about themselves. You cannot abandon reason to a bias. You've said so yourself.[/I]
That's cold man, calling me a materialist. :wink:
LG, you don't understand me at all. I am a materialist when it comes to reasoning about material issues. I am also a husband when my wife gets home in a few minutes, a son when my mom calls, a friend when I get together with them, a racquetball player in the tournament that's coming up, a meditator tomorrow morning at first light . . .
You have everything all mushed together. Why can't you keep your faith and experience of God in its own realm? Why try to mix it with rules that have nothing to do with that? I can't see how they are compatible.
Mother-reason weeps, I say.
Yes, because you are trying to turn your mother into a goddess rather than loving her for what she is.
  • #39
I am glad you said that because it is the example I need to demonstrate the bias that stems from believing something too strongly.
In Tom’s first post here he asked if when applying the pragmatic reasoning concept I was proposing, it might not be a good idea to test a theory by “. . . looking for instances in which it fails.” I still don’t think that should be the primary approach (in philosophy at least), but I think he is right too. The way I would do it is, after all the ways an idea is shown to work, then look for how it fails to work (of course, some ideas are so bad they only fail to work, so you can just jump right to that).
Okay, you say chemogenesis is “perfectly reasonable according to available evidence,” but really it isn’t and I think if you weren’t over-committed to a materialistic explanation for life you already would have seen that.
There is a major problem for the materialist theory there which I can’t believe isn’t noticed. The problem is that chemistry cannot be shown to spontaneously exhibit, on its own, the kind of functional and organizational system building that is present in even the simplest life form. The inferential leap from amino acids spontaneously forming and such to the sort of consistent self-organizing change needed to reach life is HUGE.
You say “there is also absolutely no evidence for any alternative,” but not only is that not a good enough reason to assume chemogenesis, that missing organizing force actually is evidence of a type. Say you were a detective investigating a report of vandalism to a house. You go there and find it is covered in mustard. There are no people around, no mustard jars, no evidence of any kind that the mustard came from somewhere else. Would you conclude that the house is oozing mustard on its own? Isn’t the lack of a means for getting that mustard there really evidence it must be somewhere else because houses are never known to ooze mustard?
Similarly, how can materialists conclude that chemistry does it alone when they can’t duplicate the kind of self-organization necessary for life? How do you build other materialist theories, such as purely physical explanations of consciousness, on top of a theory which has such a colossal evidence gap in it? Where at least is the doubt of the materialist explanation (for chemogenesis), and the openness to another variety of force present in life that would explain such self-organization?
I say the way materialists casually roll past the spontaneous self-organizing problem is a symptom of blind faith; they so are “blinded” by their belief in materialism they cannot see just how significant the chemogenesis issue is. In terms of the theme of this thread, it doesn’t matter how successful a discipline is in other areas, it doesn’t mean they get to circumvent the standards of evidence and proof for their pet theories.
Kinda off topic... but I disagree. Then again, it could be my "bias" talking..
(a) I believe that there is nothing special about life, and there is further nothing special about our form of life. I do this because the evidence I have seen suggests this. Because I cannot see a real border between life and non-life in reality, I feel that the decision of life or not is purely subjective. Ie. we consider life special because we are alive. We are the genesis of the life concept.
(b) Spontaneous self-organisation into equilibriums is observed throughout chemistry. Notice for example the way prions can rearrange other proteins around them to cause harmonisation. And how computers can program themselves in the right conditions. I have heard of a mathematical proof that ALL systems where each component can change it's behaviour based on the others eventually reach self-organisation - this is used to explain things like flocks of birds, and fire flies, which form without an unifying system. This is not on the scale of life, but it can and does occur. We have shown that such self organisation occurs.
(c) A belief in the possibility of chemogenesis is justified. Everything has a possibility - unless there is an expressed reason that there is no possibility. There is a possibility that God exists. That material laws are just lucky chance. Investigations into life has thus far revealed nothing other than chemistry. It is reasonable to use this extrapolation, but given lack of data without too much confidence.
(d) It is not a proof for chemogenesis, but this theory's superiority to others is that it can be rationalised to at least some degree. It is possible to do work on chemogenesis to disprove it, to improve the theory and our understanding of the processes involved. However, other theories do not allow this. You cannot investigate God. Hence, chemogenesis exists as a working hypothesis, even if this line of investigation forms a disproof by contradiction. Like prove root 2 is irrational - to begin with the assumption it is irrational leads nowhere - you begin by assuming what you can tests, and see if you are forced into the other option.
  • #40
Originally posted by FZ+
. . . I cannot see a real border between life and non-life in reality, I feel that the decision of life or not is purely subjective. Ie. we consider life special because we are alive. We are the genesis of the life concept.
Possibly so.
I will do my best to keep what I say within the bounds of this thread. My challenge was that the theory of chemogenesis does not "work" sufficiently to justify the confidence with which it is preached by the scientific community. Doing so therefore violates the pragmatic rule of reason.
I bet you anything if you were to consider the above rational you gave for explaining the self-organization of life with the same sceptism you ran your "Debunkathon" over in the pseudoscience section, you'd find it just as full of holes as I do. You have in actuality offered very little evidence of spontaneous chemical organization (and you can't use computer programs or bird flocks as examples because they are either humanly created or are already living -- you need to show chemistry doing it from scratch).
Have you ever read how a skilled creationist will try to reconcile biblical accounts with scientific discoveries? They link up the Bible with something here and there, and then conclude the Bible had it right all along. Meanwhile the gaps between the coincidences far outweigh what they have. That is what your examples amount to. What you show is the potential for chemistry to be made to undergo organizational growth, but you don't show it can do it by itself.
All purely physical (i.e., outside the influence of life or consciousness) spontaneous organization just goes on for a few steps in repetitive patterns, while life’s organization has been essentially perpetual and highly creative. Citing as significant the spontaneous formation of organic molecules, such as amino acids or the development of proteinoid microspheres fails to take into account that chemical complexity is an essential part of life, and that life most likely developed out of Earth’s chemistry, so we should expect elementary bio-stuff to result in the right conditions.
This is where your reasoning turns false because you don't address the actual objection to finding chemogenesis "perfectly reasonable." The potential for merely spontaneously forming organic molecules etc. is not the issue. The issue is full chemogenesis that spontaneously begins with perpetual development; and not just perpetual development, but of systems; and not just any system but functioning systems; and not just any functionality but hierarchally arranged functionality; and not just any hierarchally arranged functionality, but one which develops in support of the overall organization; and finally, not just any organization but one which metabolizes, reproduces and evolves.
That is the kind of organization even the lowest life form exhibits, and thus far the observed potentials of chemistry to spontaneously act fall vastly short of that level of self-organization. And this is exactly what I mean by being blinded by one's commitment to some philosophy, because it is so difficult for someone who wants to believe their philosophy to even see such a glaring problem their theory.
A belief in the possibility of chemogenesis is justified. Everything has a possibility - unless there is an expressed reason that there is no possibility. There is a possibility that God exists. That material laws are just lucky chance. Investigations into life has thus far revealed nothing other than chemistry. It is reasonable to use this extrapolation, but given lack of data without too much confidence. . . . It is not a proof for chemogenesis, but this theory's superiority to others is that it can be rationalised to at least some degree. It is possible to do work on chemogenesis to disprove it, to improve the theory and our understanding of the processes involved. However, other theories do not allow this. You cannot investigate God. Hence, chemogenesis exists as a working hypothesis, even if this line of investigation forms a disproof by contradiction. Like prove root 2 is irrational - to begin with the assumption it is irrational leads nowhere - you begin by assuming what you can tests, and see if you are forced into the other option.
Possibly you just indicated part of your reason for holding so tightly to your philosophy. Who said anything about God?
I am perfectly willing to accept chemistry as capable of self-organizing itself into life if you can show me chemistry's potential for that. I believe another principle is involved only because there are no examples of chemistry behaving that way by itself . . . but that principle doesn't have to be God! What do I care what the principle is, I just want the truth. But something unusual is going on there, why can't you see it?
If one is committed to materialism or theism, or anything really other than the truth, then one's theories have to exclude the chance for a competing theory to be correct. This leads to ignoring or "dismissing" contradictory evidence and ideas, glossing over problems that really need to be solved in order to have full confidence in a theory, and then reasoning with that compromised mess until it leads to the conclusion one wants.
This is precisely why I suggested the pragmatic reasoning concept.
  • #41
You aren't paying attention: I am telling you that "true logic" cannot take you to any position!
Here is some "true logic":
p-->q
~q
_____
~p
Now, did that take you to any "position"? No?
Me either.
Well then you shoot your own argument in the foot, because you yourself argue for such an existence. You call it "The Mind".
The fact of the matter is, using only logic + awareness of my own sensations, I can only get to solipsism without making use of an inductive argument (namely, the argument that concludes that there are other minds besides mine).
All of your arguments are invalid, and we have explained why in great detail.
Again, you seem to be referring to that "superlogic" that doesn't exist.
Exactly! So it is time for you to start philosophizing, and stop preaching. You consistently use the invalid arguments of appeal to ignorance "The Mind cannot be disproven, therefore The Mind exists" and appeal to incredulity ("I cannot accept that a material world exists, therefore the material world does not exist").
That is the basis of all religions, including your own.
Blah, blah blah.
Ahrkon and I have both explained to you that compatibility is not the same as logical entailment.
As usual, you just keep ignoring it.
I agree with the first sentence, but not with the last.
I hate to break it to you, but "The Mind" has only existed since you made it up, and it will cease to exist once you drop this foolishness.
Tom: In fact, it (edit: The Mind) cannot explain anything rationally.
LG: Such as?
When I say "anything", I mean "anything". Your Mind hypothesis does not offer any explanation for anything that we observe. In fact, no a priori argument does that.
You aren't even trying to see LW Sleeth's point, which is too bad because it's a good one.
OK, maybe this will get it through to you. In one deft stroke, I am going to use pragmatism and show the whole forum how it does not necessarily exclude anything nonmaterial. Ready? Here goes:
I, Tom challenge you, Lifegazer to present the decision procedure by which you determine the truth value of any given premise. Note that I am not asking you to present your ideas on reality, but on logic. It would be best if you would lay it out in much the same way as I did in my thread, Logic Notes. Then, we can all use it to determine the truth value of statements that are known to be true, such as "Some apples have red skins".
If you can't do that, then it is time for you to concede that "absolute truth" about reality is unattainable by any existing logic, and that observation is needed to get anywhere with it.
  • #42
But you see, the subjectivity inevitable come in when you define your "sufficiently". How well does a theory has to work? How well does a theory in development has to work? IMHO, and that is very humble, sufficient in science means better than other theories. If we have another scientific theory (Defined by Popper as one which is falsifiable), then chemogenesis would be compared to it and may well fail. But as of now, it's the best we have got. Back in the 18th century, should we have dumped Newton, because Relativity may replace it?
But notice in Debunkathon, than was a focus on finding alternative approaches. Skepticism is fruitless without such alternatives. (Besides, the computer program I mean are done with genetic programming, and hence are not really created by man, chemical crystal self-organisation are certainly not alive, firefly investigation is based on them as being astonishingly stupid, there is a certain chemical reaction that does generate rythmic pulses of colour etc etc... Look for a book called "Sync: The emerging science of spontaneous order", by Steven Strogatz. It goes on more about this.)
There lies my key objection to your system, which I just now made up on the spot and is kinda a bit of a devil's adocate. Who decides the pragmatism? Who decides sufficient proof? With such uncertainty, it seems that anyone can use it to suggest the strength of their theory. What is to safeguard pragmatism becoming morphed into a flexible system of self-excusing?
But you cannot prove the impossibility of their creationism, can you? You can demonstrate the inconsistency of their arguments... until you get bored of it... But you cannot firming say - God cannot make life. Or whatever. The change about chemogenesis is the capacity for further development. The bible is already written - chemogenesis is not. Give it time before you burn the book! :smile: BTW, the book is called spontaneous order, because it does so by itself.
But notice one difference between the computer models, that make chemogenesis more likely in real life - the fact the real environment changes! Creativity emerges out of unexpected factors! If we left life in a static environment, free from influences, then it too stagnates. Remove the physical prompts to change, the entrance of mutations etc, and what do we have? A highly repetitive series of binary fissions, resulting in bacteria... and more bacteria... and more bacteria... Early life was very boring...
You see, whenever a creationist looks at natural selection, they ask - isn't it just the same old thing recirculating? How can we get development? How do we get these systems? This is because of the direct input of originality from the environment and from physicality - this is what they forget. Life isn't creative - it feeds on the creativity, the potential wells of the world around it. Is that glaringly obvious?
Second objection to system follows: contravenes classic law of debate the argument, not the arguer. If you make the presumption of the other's "corruption", you lay yourself open to big bias, and blind yourself to rational discussion. I raised God, because I thought it was the only open alternative. But if it was anything else, it still falls to the same problems - it isn't testable, and hence is not scientific, and hence cannot be shown one way or the other. Of course, if you have one that is, don't hide it from me! As yet, ironically enough, chemogenesis is the only scientific theory, because it is the only one we can prove FALSE. It's the only path we can make progress on, even if it is proving it false.
But chemogenesis doesn't exclude the chance for any alternatives. Because the other alternatives aren't even on the same playing fields. A material theory can never affect one that is based on spirituality, or any other non-material concepts. You see, we don't gloss over the contradictory evidence, because we don't have a lot of evidence at all yet. Chemogenesis is a young science, and one that seems from the progress made to hold promise. As to the problems, the fact is, they are still being solved. For the time being, the fact it still remain the only theory we can solve, that we can check for problems, that we do not know everything in, that still contains unknowns, makes it one to have confidence in, at least in it's possibility. Because right now, we don't actually have a choice. It's a crime of desperation. Give me some leniency!
  • #43
The Mind does not exist beyond sensation, any more than the mind exists beyond its own thoughts or its own feelings. This is just a misunderstanding of my philosophy on your part.
The Mind is proven by direct experience. The existence we experience is one of mindful-attributes. Sensation; reason; emotion; imagination; will. Abstract existence.
Rather: there is no reason to prove that an external-reality exists. Therefore, being a reasonable-being, I cannot simply "believe" that an external-reality exists... any more than I can simply believe in 'santas'.
Do you know of any other hypothesis which makes-sense of the duality of classical-physics and QM? Do you know of any other hypothesis which makes-sense of the individuality of space-time experience?
You scoff at my hypothesis, yet it is highly significant that my hypothesis is compatible with science.
My argument proceeds from direct experience - not assumption. And since it can explain the apparent duality of existence, I say that it explains quite alot.
LWS is not practising what he is preaching. He believes that reason cannot be confirmed without sensationed-verification. In that case, we need to abolish mathematics, for starters.
I'll respond to this later. I
  • #44
FZ,
You are right in that this pragmatic approach involves some subjectivity. But surely science already does this sort of thing now? If science doesn't have a rigid process that helps it move from statements like "nature could be doing this" into statements like "nature IS doing this", then no wonder we have so many people with opposing views claiming their views are the Truth. I think LWSleeth is proposing a rigid method that involves less subjectivity then what is currently being used; in these forums for sure.
At the risk of putting words in LWSleeth's keyboard, let me say that I don't think LWSleeth is saying that his method of pragmatism should be used to completely write a theory off and eliminate it's research efforts. I think the main point is that this method should be used to determine what can be considered "confident knowledge". It can tell us whether we should be confident enough to sign on to physics forums and talk about a theory as if it's true. Which happens here all the time.
So, I don't think LWSleeth's point is to take away leniency from you in researching this new theory. But you don't have leniency when it comes to preaching this theory as the truth. It seems you agree with this with regard to Chemogenesis as you said there was a lot of progress to be made. Perhaps you can help remind people like DT Strain of this when they are preaching it as gospel.
And to interject my own opinion here, science cannot claim to be searching for truth when it's scope is only on what is falsifiable. THE TRUTH MAY NOT BE FALSIFIBLE. Overall I think the mustard example was one of the best I've heard. It may be true that the only thing we are capable of doing is to research how mustard leaks from the house. But that doesn't mean that's the way it happened. So should we be going around and claiming that it is the way it happened simply because our only other alternative is to say "I don't know"? There's nothing wrong with this phrase. I say this phrase all the time. Because it's usually true. :smile: And truth is what I'm interested in.
I would much rather someone say this phrase then to pretend their best guess is truth.
  • #45
I am just raising the possibility of a dark side to this... And the possibility that this pragmatic approach may not be so different from what we do already anyway...
*cue self righteous ranting*
The point is that the possibility of chemogenesis at present cannot be denied - I didn't make a statement on probability. I didn't say chemogenesis has to be true, but rather it can be true. To say as a statement that chemogenesis cannot be true is a statement in itself, and one that claims more absolute (and hence unreasonable) knowledge that a statement of possibility. Rather, I am not preaching this theory. I am saying - yes, there are problems, yes there are things that need to be solved, but as far as we see, this theory has promise. It has possibility. Denial cannot, in my humble opinion be justified. Though I disagree profoundly with creationists, I cannot go so far as to say creationism is impossible. In a statement of "can", the acceptance has to be made that anything "can". It's a matter of "does". Lack of data, instead of contrary data, cannot be a DISPROOF for a theory.
And to interject my own opinion here, science cannot claim to be searching for truth when it's scope is only on what is falsifiable. THE TRUTH MAY NOT BE FALSIFIBLE. Overall I think the mustard example was one of the best I've heard. It may be true that the only thing we are capable of doing is to research how mustard leaks from the house. But that doesn't mean that's the way it happened. So should we be going around and claiming that it is the way it happened simply because our only other alternative is to say "I don't know"? There's nothing wrong with this phrase. I say this phrase all the time. Because it's usually true. And truth is what I'm interested in.
Well, what do you know? I disagree!
The fact is that science is about the search for truth. Science accepts that truth may not be reachable. What is truth really? If we have something that is true, how do we know that? This is where science is the key. Science works by eliminating untruths, and creating understanding. IMHO, there is no other way. Let's say that the truth is that God exists. How can we tell? We can't. We really can't. The result is that science can be really the only process searching for the truth, as opposed to guessing at the truth. It's the only route to progress. Science is about progress. And falsifiability, testability is the road to progress. Science isn't about Truth - it's about looking for the truer, and throwing out the untruth. You may be interested in the Truth, but you will never reach it. Especially if it is not falsifiable. No one claims there best guess is the truth - rather it is apparently more true than the others.
"I don't know" is never an answer. It is only the beginning of a road. If "I don't know" was an answer, then there is no reason for life, for knowledge. Apathy is the enemy of the search for truth.
  • #46
Perhaps. But I think it has a lot more structure than what most people here do. Maybe this idea just needs some further definition?
I agree with all you're saying. But there are people who post in this forum who do not concede the "problems" that you mention. It is simply "truth" to them. I think this attitude is what has motivated LWSleeth.
"I don't know" is never an answer. It is only the beginning of a road. If "I don't know" was an answer, then there is no reason for life, for knowledge. Apathy is the enemy of the search for truth. [/B]
I understand everything you've written and can agree with it for the most part. But I still have trouble with a discipline that admits it cannot have complete knowledge but yet won't acknowledge where that lack of knowledge resides. If all we're going to do is accept our best guess as truth then how do we reconcile that with the idea that we cannot have complete knowledge? For if a falsifiable best guess is all we need, then surely we can have a "truth" for everything. I realize that you said "truer" and not "true" but others here HAVE taken this attitude. It's good to see that you aren't.
I'm not arguing for apathy. I'm arguing for proper representation of what we know and what we don't know.
Actually, I don't think you and I disagree at all. But there are people here who will not acknowledge the "problems" of their pet theories or, if they do acknowledge them, will not acknowledge that those problems could lead to a better theory. It is these people that should be put in check. But I agree the research should continue. Let's just be honest about how good our best theory is. And for me, if 2% confidence is all we can claim, then "I don't know" is the best answer. At least until more knowledge is gained.
  • #47
I agree, but the problem is you can't really quantify things like that. The question "What percentage of everything do we know?" is nonsensical, because we happen not to know how much there really is to know - or whether there is an infinite amount to be known. You see, since we don't have the knowledge, we can't really always point out where the lack of knowledge lies - just that it is in there "somewhere"...
  • #48
I prefer to do it in my own style, if you don't mind?
Anyway, I flow better when I'm not constrained by method.
"Lifegazer to present the decision procedure by which you determine the truth value of any given premise."
... is the challenge.
Existence is experienced through sensation, and understood via the reasoning of those sensations.
... Is what I would class as an absolute-truth. For how can it really be faulted? Everybody knows what I mean, and everybody has the exact same experience. I do not need to prove this premise, any more than you need to prove your own existence to yourself. And yes, the true identity of existence has not been proven by the premise alone. But it is a sound-premise upon which to build a philosophical-argument.
An external-reality does exist.
... Is what I call a challengeable-premise, for obvious reasons. Nobody has direct-experience of this premise, and there is no logical-argument to even prove that this is logically-acceptable. In short, the reader of the premise has to believe that the premise is true, in order to follow the conclusions of that premise.
Hence, the truth value of any given premise, is in the absoluteness of that premise. I.e., there is no reasonable basis upon which to refute the premise - since it is pointless to reason against the absoluteness of experience, when the absoluteness of experience is the foundation of known-existence.
This is why I think that scientific-Laws are sound premises for an argument. They mirror the behavioural-order of our sensations. We all share the same laws of sensationed-behaviour. Therefore, there is an absoluteness about the physical-laws. A singularness.
If reason emanates from the self, and reason is founded upon direct self-experience, then there are some absolutes which can be declared about this sensationed-Existence.
  • #49
No, I understand your religion just fine. This point that I made really is part of why it is so incoherent. You say on the one hand that there is no way to prove that an external reality outside of one's mind, and then you claim the existence of some "Super Mind", which is definitely outside of one's mind.
Surely you see the contradiction there.
Sure, my mind is proven by direct experience. As for "The Mind", that is not.
Sorry, you cannot have it both ways. You cannot say on the one hand that there is no external reality (and thus be a solipsist) and then claim that there is a god (and thus be a theist). Those two notions directly contradict each other.
Again: Blah, blah, blah.
It has been explained to you repeatedly that:
1. Your hypothesis does not explain any of those things.
2. It is completely insignificant that your hypothesis is compatible with science. Any nonfalsifiable hypothesis is compatible with science.
You are wrong on both counts. First, your argument makes plenty of assumptions. All one has to do is insert the missing logical links to see them. One of your assumptions is that a mind can exist without a brain, for example. Second, your argument does not explain anything observed in nature. I don't know why we have to keep repeating that to you.
You are so confused.
The whole point of this exercise is that pure logic can only be used on abstract objects, and not on the concrete objects of reality. This is because only abstract objects can be known a priori. The objects of mathematics are abstract objects, and so pure logic is fine to give mathematical proofs. Proofs about the objects of reality, that cannot be known a priori, must include evidence.
All of this has been discussed in detail in this very thread, and you seem to have ignored all of it.
  • #50
OK, but I am noting that you aren't offering a proof of this.
OK, I agree that this cannot be proven with deductive logic alone. That leaves us stuck with solipsism, without making an inductive leap, namely the leap to "other minds".
This is where you hit a brick wall. This is nothing more than the argument from ignorance that you are so fond of. It says, "X has never been proven/disproven, therefore X is false/true."
That is invalid reasoning, and it has been explained to you repeatedly.
This does not qualify as a deductive decision procedure for establishing the truth of a premise.
  • #51
Like I said, the premise is universally-experienced. The proof resides within the direct-experience and universality of it. I have nothing to prove, any more than you need to prove to yourself that you exist.
This is another aspect of my philosophy which you don't understand. I do not advocate that there are "other minds". I advocate that there is One Mind ~lost~ in countless relative-perceptions of existence, and unbounded by timely-constraint.
Lg:- "Hence, the truth value of any given premise, is in the absoluteness of that premise. I.e., there is no reasonable basis upon which to refute the premise - since it is pointless to reason against the absoluteness of experience, when the absoluteness of experience is the foundation of known-existence."
Actually, known-existence is dependent upon the self-awareness (through self-sensation) of existence + the ability to comprehend what is being sensed. It is rationally-impossible to disprove the aforementioned premise and the premise is a necessity for having knowledge of existence. It's as timeless a premise as you're ever likely to see.
I cannot agree, since you have given me no reason to agree - in relation to my prior post.
  • #52
No, I understand it. I just understand that it is nonsense. You do not really know of any mind beyond your own. Whether you choose to make an inductive leap to "other minds" or "One Mind", you make a leap all the same.
edit--Correction: In making the leap to "other minds", you make an inductive generalization based on observed behavior of other bodies. In making the leap to "One Mind", there is no induction because there is no evidence. It is truly pure faith.
The only "absolute" I'm willing to give you here is the subjective proof I have that my own mind exists. One cannot prove with pure logic that anything other than the self exists. Observations have to be made, and inductive generalizations have to be made from them. Yes, I know for certain that I am thinking, but that cannot be used to logically derive any truth about objective reality.
At least, I have not been presented with any deductive decision procedure that allows me to do that objectively. That's what you're supposed to be providing here.
You seem to be saying here that "any given premise" about reality can be determined true or false simply on the basis of the absoluteness of existence. I imagine that you are led to this mistake by a prior mistake, namely by your irrational assumption that human minds are equipped with absolute knowledge of the workings of nature, which is patently false.
It really is quite irrelevant that you disagree. Deductive logic is not a matter of opinion. It is as rigorous and well-defined as mathematics. That is why I asked you to follow a systematic style like in my Logic Notes (or any logic textbook), because that is what is called for here.
The fact is, your decision procedure boils down to argument from ignorance, which is not valid. Valid argument schema used with true premises always lead to true conclusions. The schema for the variant of the argument from ignorance that you are using is, as I said many times before:
X has never been disproven, therefore X is true.
Let's examine the validity of this schema.
Argument 1:
It has never been disproven that the core of Pluto is solid gold, therefore the core of Pluto is solid gold.
Argument 2:
It has never been disproven that the core of Pluto is solid silver, therefore the core of Pluto is solid silver.
Conclusions 1 and 2 are mutually exclusive, so they cannot both be true--but the premises of both arguments are true!. Therefore, the argument schema itself is invalid.
So, it is not enough to say that a statement is true if there is no disproof of it, and I repeat: What you presented does not qualify as a deductive decision procedure for assigning truth values to premises.
  • #53
That was a pretty good post FZ (even if it's wrong ) which I, the only person more humble than you, am about to demonstrate.
First, what Fliption said is my main objection. When I see a TV special on evolution begin with the phrase "life most likely began in the chemical soup of Earth's early ocean when the right chemical/physical conditions spontaneously self-organized themselves into the first living system" . . . THAT is where I have a problem. It is the "most likely" which is not justified by the evidence.
Just because you claim it is the best evidence you have doesn't mean you can ignore a critical flaw in a theory; and I don't think it is even accurate to say it’s the best theory, but rather it is the best theory materialists have. In my (humble) opinion it is every bit as hole-ly as creationism in this respect.
Chemogenesis is based on an a priori assumption that existence is material -- that is what makes someone say the only possible explanation for the life phenomenon must be material. If one doesn't proceed on that assumption, I say one would be more conservative in suggesting chemogenesis than most materialists are.
My observation isn’t an ad hominem argument, it is derived from analyzing the evidence supporting the chemogenesis hypothesis and then observing how much scientism advocates express confidence in it. What other reason would explain their exaggerated certainty if not from already assuming only a material explanation is possible for the origin of life?
By the way, you don’t know whether you can prove chemogenesis false yet. If it can never be demonstrated, there is still is the possibility the right combination of conditions that causes it just have never been recreated. As of now, it is a theory that is not very testable because no one is making real progress on it. There’s been nothing very significant since the decades-old Urey and Miller demonstration, and even then all that did was show that the potential for life’s chemistry is present on Earth.
You say, “For the time being, the fact it still remain the only theory we can solve, that we can check for problems . . . [and that] makes it one to have confidence in.” Well, you haven’t shown it can be solved, and the biggest problem of all with it scientism proponents seem in denial about, so I cannot see a realistic basis for your confidence.
. . . the fact the real environment changes! Creativity emerges out of unexpected factors! If we left life in a static environment, free from influences, then it too stagnates. Remove the physical prompts to change, the entrance of mutations etc, and what do we have? A highly repetitive series of binary fissions, resulting in bacteria... and more bacteria... and more bacteria... Early life was very boring . . . How can we get development? How do we get these systems? This is because of the direct input of originality from the environment and from physicality - this is what they forget. Life isn't creative - it feeds on the creativity, the potential wells of the world around it. Is that glaringly obvious?
You've avoided addressing the real flaw in the chemogenesis theory with the sort of argument chemogenesis proponents use all the time. The argument is one where you move on into life processes, show how extensively life is embedded in materiality, and then conclude it is strong evidence that life is materially generated.
I do not dispute the role of the environment in shaping life forms' character. But that molding by natural selection is taking place on something, something even as simple as prokaryote life, which has a potential far different from ordinary matter.
Then you pointed to the ability of matter to self-organize saying, “. . . chemical crystal self-organization are certainly not alive . . . a certain chemical reaction that does generate rhythmic pulses of colour etc etc . . . the book is called spontaneous order, because it does so by itself.”
I’ve agreed matter can self-organize, but we both know it can only do it for a few steps. If you think crystal self-organization is a proper example, and it is the environment that transforms the few steps of normal self-organizing matter into perpetual system-building matter, then let’s put a bunch of crystals in any environment you choose, change it anyway you like, and let’s see if you get those crystals to move past repetitive change and start evolving.
In other words, show the minimum necessary to indicate an evolutive change principle present in the potentials of matter. If you can’t even establish how something so basic "works," then how can reason convince you to be confident in chemogenesis?
  • #54
I don't think that is a fair assessment of me, although I am pretty sure why you think so, and I don’t think you know what I am preaching yet.
Anyway, your mathematics example is a good one since that actually is something which you can verify is true without requiring observation. That’s because mathematics, like logic, is proven by rules internal to the system. So when you are done with doing math, you can test it by its own rules.
The problem for knowing arises when you want apply a system of proof for something which lies outside yourself. In your mind you can imagine, calculate, predict and apply perfect logic while you reason about it, but how do you know if you are reasoning with the correct information? The “rules” of the thing you are investigating are internal to it, not you, so while you can be certain of the rules of reason (since they are internal to you), you cannot be certain of the rules of the “thing.”
Hence we add experience to the formula, and what do we get? We get an avenue for the rules of the “thing” to enter into our own internal system. Now reason can really do its thing with an external. How do we know we can trust this approach? Answering that question is what I’ve suggested as a standard for philosophical discussion, which is we see if a proposed idea “works” in some way. When it comes to experience plus reason, we can see in empiricism at least it has worked very well indeed. What that tells us is that experience plus reason matches with reality in some respect precisely because it does work.
I also am going to take a bit of an inferential leap from this idea and say that the incredible qualitative change that took place once experience was added to reasoning suggests the role of experience in knowing may be absolute, and that includes subjects like God or the Mind. That is, if one hasn’t experienced them, then one knows nothing about them (one could, of course, become an expert on what others who claim experience have to say, but that isn’t personally knowing the subject itself).
I said to you awhile back that this is where you need to “get up to speed.” I said that because the system of reason you advocate was practiced for many centuries, and most of that intellectualizing is now rotting in a big heap of uselessness. It’s not that maybe some of it wasn’t on target; it’s just that without any way to test ideas, the speculation is endless! And lots of it really was crap too. But if you have to show your idea’s efficacy for it to be considered, then you can weed out all the garbage and get down to thinking about ideas with promise.
And then, I still say, for true seekers of knowledge, thinking is just to help one figure out where to look for experience. So, for instance, if you are interested in genuinely knowing the Mind rather than just thinking about it, you will find a way to have a direct experience.
  • #55
For a thread supposidly devoted to pragmatism this is getting about as abstruse as they come. Ya'll are so busy debating Chemogenesis pragmatism seems about as distant as it can get. Why not debate how many angels can dance on the head of a pin and then talk about how this is related to pragmatism. I think you might have a better chance or reconciling your differences. Just a thought. :0)
  • #56
It may not be apparent, but the subject of chemogenesis is related to this thread because I claim it is an example of something that violates the pragmatic reasoning standard. Personally I find too much theorizing without discussing real-life examples to be too mental, so I am okay with a thread wandering a bit as long as things don't get too far off topic. However, I have decided to start another thread to focus on evolution.
  • #57
I agree. But I thnink this is exactly why we need a process like what LWSleeth is describing. Any method you choose will be subjective but some standard is better than none.
  • #58
Continued in Chemogenesis thread in Other Sciences.
  • #59
Exactly.
But what does this mean? Does it imply that the system is 'subjective'? Of course not. The mathematics system is rationally-sound. And reason is not founded upon a set of systems. Rather, reason is the foundation for the definition of systems. Reason precedes all reasoning. Reason defines herself.
I'm really struggling to see the point of making such a remark. Does it seek to nullify the absoluteness of reason? How ironic, when reason swings between absolute-concepts and relative-definitions.
Reason knows what she's doing. If this wasn't so, then math would not make sense; and physics would be a waste of time. There is an absoluteness about reason, which is the foundation of all philosophy. The kind of absoluteness-ness which created math itself.
... Okay, people often disagree about lots of issues. But this isn't a proof that reason is not absolute in herself. It's just a proof that we regularly abuse reason in the construction of an argument. I.e., it is the effects of reason which have been relative, rather than the cause - reason herself.
Scientific-Law is an accurate depiction of our perceptions. Mathematics is a sound-system of numerical linguistics. And reason is absolute in herself.
Like I said in an earlier post: You can trust all knowledge which is universal. Clearly, the ~knowledge~ that there is an external-reality is challengeable. Thus... untrustworthy. But you will have a hard time challenging my hypothesis with reason. Which means that you cannot challenge my reason for the hypothesis. Which means that my reason is universal. LOL
It is clear to me that we are at loggerheads on only a few significant points. I doubt that either of us will ever exchange positions. But the convo is good. Cheers.
  • #60
Let us use some logic then, while I sit on a chair in front of my PC. I percieve of a chair, it's the one I am sitting on. I can feel the metal and non-metal parts, and see it, hear it (when "rolling" the chair), etc.
We been there many times, and all you had to say is that we only know about the chair because of the "impressions" our senses give us to our minds. But now let me ask a very ordinary question. Where do I sit on? Well ordinary people, using ordinary logic, tell they sit on a chair.
They don't sit on an "impression" of the chair, they don't sit on something that does not exist outside of their own mind, they sit on something that is truly indendend of their mind, and really existing.
Now, all those people who claim to sit on a chair, and claim, using their full capacity of logic and reason, that there really is a chair, apart from their internal representations of such a chair, of which they are of course aware, all those people in the mind of LG are either liars, or are unreasonable, because they "assume" something, that isn't really there, or can't be proven.
But this is just the start of the doctrine of which we all know where it ends. It ends in us having to believe that apart from any observation or experiment whatsoever, there exists a "supermind", and we have to accept this articial construct of thought for real, or we are all called philosophical charlatans. If not worse!
  • #61
"The chair" does exist - within your sensations.
"The chair" is truly sensed.
But who here can show that beyond sensation, such a chair exists?
  • #62
take a balance, measure it's weight and REPEAT that operation.
take a meter, measure it's height and REPEAT that operation.
take an image with a scanning device and REPEAT that operation.
hit him on your head, see if your body has damage, REPEAT that operation several times and ... REPAIR that chair
  • #63
Especially the forlast operation must be repeated several times.
It does a human being good, it increases the logic capacities...
When I was a small child, I would not believe that a fire was really hot. Well I must have been stubborn about that, and did not take anyone's advice NOT to stick one's hand in there. But I LEARNT that a fire was hot!
  • #64
You guys need to eat more fish. Everything you just said was a part of sensation. I asked you to show me how the chair exists beyond sensation, remember?
  • #65
But what does this mean? Does it imply that the system is 'subjective'? Of course not. The mathematics system is rationally-sound. And reason is not founded upon a set of systems. Rather, reason is the foundation for the definition of systems. Reason precedes all reasoning. Reason defines herself. . . . Reason knows what she's doing. If this wasn't so, then math would not make sense; and physics would be a waste of time. There is an absoluteness about reason, which is the foundation of all philosophy.
I don't think you realize it but you actually are forwarding an argument in favor of there being an external reality on the one hand, while simutaneously casting doubt on reason.
When you say there is an "absoluteness about reason, " do you know why that is so? There is only one little, tiny change that reality would have to make and reason would no long work, and that would be if the universe were to suddenly lose all its order.
Reason "works" because there is order it can follow. That order is found in the laws of physics, in the structure of matter, in the rhythms of EM and all the cycles of nature that are in harmony with that. Your brain is constructed so it can be organized by the order of the physical world you are born into.
Now, every bit of that is external to you, the consciousness inside. That reasoning you perform with your mind is based on the ways we've figured out how things are organized, and can be organized. It is because we can unfailingly count on the order of matter and physcial law that we can also rely so unfailingly on (proper) reason.
Thus when you say, "Clearly, the ~knowledge~ that there is an external-reality is challengeable. Thus... untrustworthy," you are giving a rationale for doubting the very reason you've just said is so trustworthy.
  • #66
That's not all; he also contradicts his own position that there is a god. The only knowledge he or anyone else has about minds is that knowledge pertaining to one's own mind. If one wishes to maintain the position that there is nothing external to that, then one cannot convincingly argue for a 'super mind'.
  • #67
Main Entry: sen·sa·tion
Pronunciation: sen-'sA-sh&n, s&n-
Function: noun
Etymology: Medieval Latin sensation-, sensatio, from Late Latin, understanding, idea, from Latin sensus
Date: 1615
1 a : a mental process (as seeing, hearing, or smelling) due to immediate bodily stimulation often as distinguished from awareness of the process -- compare PERCEPTION b : awareness (as of heat or pain) due to stimulation of a sense organ c : a state of consciousness of a kind usually due to physical objects or internal bodily changes <a burning sensation in his chest> d : an indefinite bodily feeling <a sensation of buoyancy>
2 : something (as a physical object, sense-datum, pain, or afterimage) that causes or is the object of sensation
3 a : a state of excited interest or feeling <their elopement caused a sensation> b : a cause of such excitement <the show was the musical sensation of the season>; especially : one (as a person) in some respect exceptional or outstanding <the rookie hitting sensation of the American League>
Sensations are subjective.
It depends of the relation between impulse/stimulus, how action creates reaction in our brains (quality and quantity of synapses, neurotransmitters, microtubules, cell structure, ... depending from our DNA , RNA, etc. ... and other states: damage, exogenous influences like alcohol, drugs, food, ... ).
Since my DNA is absolutely different from your - which gives me a profound sensational satisfaction - as you stated that : my bigger eyes (which are larger than my mind) will capture probably more light than yours. So I will be able to capture some extra IR-lightwaves like a cat in the night. That will give me a picture where you will only be able to see some light spots. Since you are although directly in contact with THE MIND you will have a much larger overhaul sensational perception and consciousness than all members of PF together.
Now because of all those different sensational impressions and interpretations by different subjects some simple people like myself - which regret not to be as privileged as are you are in being in direct contact with THE MIND - prefer to MEASURE in a REPEATABLE framework, based on CONVENTIONS. One of the main goals is to organize these measurement systems is to exclude the possibilities that personal sensations may influence the results. We call that OBJECTIVITY, facts confirmed by repeated measuring ... independent from the observer.
This humble approach tries to reduce all possible conflicts of interpretation on observed events. The main target is to exchange RESULTS and make CONCLUSIONS / THEORIES, and possible PREDICTIONS and conditional statements.
Simple people need that ... but people like you - Enlightened Representative of THE MIND - don't need such a time consuming way of exploration the various aspects of reality since everything is already set, done and clear to you. For that reason you avoid to speak in all your numerous threads about repeatable measurements, because that's the key.
  • #68
Incorrect. I have said that the sensations are real. Therefore, we do sense what appears to be an external-reality. But that appearance is completely generated by looking within ones own awareness. Hence, the question of whether this 'appearance' is in reflection of a true external-reality - which resides beyond these sensations - is completely legitimate. For if we are only looking within ourselves, then how can we know that what resides within ourselves, also resides without?
We see; taste; touch; smell; and hear the universe. And then we apply reason to these sensations. And reason notices the order inherent within these sensations. And then, because our sensations are ordered, reason is able to define different aspects ('things') within our singular-awareness - thus fragmenting awareness. Awareness is stretched and fragmented so that it can perceive of "the universe". Then reason formulates 'knowledge', via recognition of order. So 'knowledge' is actually a reflection of sensation - not an external reality.
Everything you experience, is within your own awareness. And everything you know, is a reflection of reason, upon sensation.
I can only know of my own awareness, and the knowledge which I have gleaned from It. And that's all you can do, too.
It's all self-knowledge. Since the knowledge is a reflection of an inner-existence.
Exactly. Reason is the understanding of order.
The order of the universe is not a reflection of total reason. Reason extends way beyond the universe. From nothing to infinity. From time to eternity. From God to matter. From fragmentation to singularity. From order to chaos. Reason knows more than the sensed-order we perceive of. It conceives of things which clearly cannot exist in a 4-dimensional reality comprised of tangible-things.
  • #69
LG, I don't have time to answer your post right now, maybe later this evening, but I want to ask you not to respond angrily to Pelatration. Let's keep this thread on track and civil (I admit I contributed to sending sideways with my pet peeve).
If you want to debate the Mind hypothesis, see if you can put in terms of the pragmatic reasoning process I suggested. In what way can you show it "works" as a hypothesis, and those of us who disagree with it will try to show why it doesn't work.
  • #70
Don't worry. I'm a changed man. LOL
I can no longer do this. My philosophy about God is to be automatically transferred into the religion forum. Haven't you heard?
My number is up, apparently. So much for "pragmatism", eh?
