Problem on Rotational mechanics / Conservation of angular momentum.
The discussion centers on solving a problem involving two cylinders rotating and coming into contact, where slipping ceases due to friction. The user initially solved the problem using angular impulse and the change in angular momentum but seeks a solution based on the conservation of angular momentum. They derived an expression for the new angular speeds after slipping ceases, but their result differs from the expected answer. The correct formula incorporates the radii squared in the denominator, indicating a need for careful application of conservation principles. Clarification on the correct approach to using conservation of angular momentum is requested.
cantgetaname
The figure shows two cylinders rotating about their axes, all the variables involved are shown.
The two cylinders are moved closer to touch each other keeping the axes parallel. The cylinders first slip over each other at the point of contact but slipping finally ceases due to friction between them.
Find the angular speeds of the cylinders after the slipping ceases.
  1. After slipping ceases, if w1' and w2' are new angular speeds then...
    w1' * r1 = w2' * r2
  2. Angular momentum = Iw.
I have succeeding in solving the problem by equating the angular impulse due to friction to the change in angular momentums of both cylinders and eliminating friction force from the two equations.
But I'd like to solve this using conservation of angular momentum as well since it should be pretty straightforward and easy.
Since no external torque acts on the system, conserving angular momentum, I get:
I_{1}\omega_{1}+I_{2}\omega_{2}=I_{1}\omega_{1}' + I_{2}\omega_{2}'
Using this with w1' * r1 = w2' * r2, I get
\omega_{1}' = \frac{I_{1}\omega_{1}+I_{2}\omega_{2}}{I_{1}r_{2}+I_{2}r_{1}} r_{2}
and a similar expression for w2'.
The answer, however, is \omega_{1}' = \frac{I_{1}\omega_{1}r_{2}+I_{2}\omega_{2}r_{1}}{I_{1}r_{2}^{2}+I_{2}r_{1}^{2}} r_{2}
Anyone?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
