Projectile Motion: Firing to Reach Target at Diff. Height
To solve the problem of a projectile fired at a target at a different height, one must consider the firing angle, distance, and gravitational effects. The projectile's flight time and initial velocity can be calculated using kinematic equations, taking into account the vertical and horizontal components of motion. The challenge arises from the height difference, which complicates the trajectory calculations. A common example involves firing at a 45-degree angle to a target 2000 meters away and 500 meters high. Understanding the relationship between the components of velocity and the impact of gravity is essential for accurate calculations.
Bob123456
Hello, I need to solve a problem which involves a projectile being fired at a target that is at a different height. Given a firing angle, the distance the projectile needs to needs to travel and gravity, i need to compute the flight time and initial velocity needed to reach the target. I don't have and specific problem with specific numbers to work with but I can just toss out an example.
A projectile is being fired at 45 degrees, at a target 2000 meters away and 500 meters off of the ground.
The difference in height is completely throwing me off.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
