Pulley system problem: 6 Pulleys and 1 Mass
The discussion focuses on a pulley system involving a mass of 5 kg and the application of a force F. The analysis includes free body diagrams for the mass and the pulleys, leading to the conclusion that the tensions T1 and T2 are equal and both equal to 50N. The reasoning presented is confirmed as correct by other participants, highlighting the clarity of the explanation. The original poster expresses a desire for validation of their understanding despite lacking formal training in physics. Overall, the thread emphasizes the importance of clear reasoning in problem-solving.
david3305
Find force F
m_1 = 5kg, g = 10 m/s^2
The following system is at rest with a block of mass m1 = 5kg, and a force F that is applied to the end of a string attached to the pulley system. Let g, the acceleration due to gravity equal to 10 (for simple calculations).
My analysis is as follows:
I'll first label the strings Tsub1 and Tsub2, and each pulley in red P1 and P2 (in red):
From here I'll make 3 free body diagrams:
m1:
$$\begin{array}{rcl} & T_{1} = gm_{1} = 50N \\ \end{array}$$
then P1:
$$\begin{array}{rcl} &T_{x} = 2T_{1} \end{array}$$
then P2:
$$\begin{array}{rcl} &T_{x} = 2T_{2} \end{array}$$
From these equations we have that
$$\begin{array}{rcl} &T_{1} = T_{2} \end{array}$$
and therefore
$$\begin{array}{rcl} &T_{1} = T_{2} = F = 50N \end{array}$$
Is there a question you wish to ask about this?
Sorry, I just wanted to know if my reasoning is correct. Im just a simple man trying to figure out stuff on my own without any formal training. In fact, I didn't even took physics in highschool, back in the day it wasn't required on my 3rd world country.
If you do/don't have formal training, your free body diagrams look well done/reasoned to me.
Thanks, thats Khan Academy and a bunch of youtube videos for you.
Your reasoning is correct. I wish that more of my students explained theirs as clearly as you did.
Likes berkeman and erobz
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
