Purcell 1.77 Electron jelly
  • Thread starter Thread starter Rob2024
The discussion revolves around the challenges of minimizing the energy method for calculating potential energy in the context of a charged sphere. The initial approach using energy equations was deemed ineffective, leading to the realization that the force balance method yields correct results. There is confusion regarding the symbols used, particularly the sphere's radius, which is referred to inconsistently. A suggestion is made to reevaluate the potential due to the negative charge and to reference established formulas for potential inside a uniformly charged sphere. Ultimately, the user acknowledges a misapplication of the potential energy concept, which has been clarified through the discussion.
Rob2024
Imagine a sphere of radius a filled with negative charge of uniform
density, the total charge being equivalent to that of two electrons.
Imbed in this jelly of negative charge two protons, and assume that,
in spite of their presence, the negative charge distribution remains
uniform. Where must the protons be located so that the force on
each of them is zero? (This is a surprisingly realistic caricature of
a hydrogen molecule; the magic that keeps the electron cloud in
the molecule from collapsing around the protons is explained by
quantum mechanics!)
##U= \frac{k Qq}{r}, E = \frac{kQ}{r^2}##
I initially tried energy method, I realized this cannot be minimized.
##U = \frac{kq^2}{2r} - \frac{2 k qq'}{r} , q' = \frac{2e r^3}{R^3},q = e ##
##U = \frac{kq^2}{2r} - \frac{2 k q\frac{2e r^3}{R^3}}{r} ##
##= k q^2 ( 1/2r -4 r^2/R^3) ##
##= \frac{1}{2} k q^2 ( r - 8 r^2/R^3) ##
##U' \sim -1/2r^2 - 8 r/R^3 = 0 ##
The force balance method works correctly.
##E = \frac{k q}{4 r^2}, E' = \frac{k q'}{r^2} = \frac{ k 2 q r^3/R^3}{r^2} ##
##r = \frac{1}{2} R##
I cannot figure out what is causing this inconsistency.
The meanings of your symbols are not always clear and you have not provided any explanations of the rationale. But I think I can guess. Also you have used '##R##' for the sphere's radius but the question calls it 'a'.
Consider the potential a distance ##r## from the centre of the sphere due to the negative charge alone. The potential is not ## \frac{k \frac{-2e r^3}{R^3}}{r}##.
You can try working out the correct expression for yourself or do a search such as 'potential inside a uniformly charged sphere'.
Likes berkeman, Rob2024 and TSny
Thanks, this worked. I used the potential energy incorrectly.
Likes TSny, Steve4Physics and berkeman
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
