Question about Convective Heat Transfer Coefficient?
The discussion revolves around calculating the thermal resistance of a wall with an air gap, where the convective heat transfer coefficient is not provided. Participants clarify that the convective heat transfer resistance on either side of the wall is irrelevant for this specific calculation, as the air is still, making convection negligible. The correct approach involves using the formula R = L/k for the wall and air gap. The final calculation yields a total thermal resistance of approximately 2.1861 °C/W. Overall, the focus is on understanding the conduction aspect rather than convection in this scenario.
LaReina
The cross section of a wall is shown in the figure below. To reduce the heat flow, an air gap (still air) of 6cm is created between the brick wall layers of 14cm thick, each. The thermal conductivities of the brick wall and the still air are: Kair = 0.032 W/m.K and Kbrick = 0.9 W/m.K, respectively.
Calculate thermal resistance.
This is only part of the question as I have no problem with the rest. The convective heat transfer coefficient has not been given thus making it very difficult for me to even begin.
R=1/hA
R=L/kA
Q=T1-T2/Rtotal
As no convective heat transfer coefficient has been given, I can't even begin to calculate the thermal resistance. It's probably something very simple but I just can't get my head around it.
Hi LaRiena. Welcome to Physics Forums.
They are only asking for the thermal resistance of the wall, so the convective heat transfer resistance on either side of the wall is not relevant to the question. Since the air within the wall is still, convective heat transfer within the air compartment is negligible. This is a straightforward conduction problem.
Chet
Chet
Hi Chet
Thank you for your response.
Correct me if I'm wrong but since the convective heat transfer coefficient is negligent would I use R=L/k instead to find the thermal resistance?
So Rtotal=((0.14/0.9) x 2) + 0.06/0.032
Rtotal=2.1861 °C/W
Yes. This looks correct to me.
When you are talking about the possibility of convective heat transfer within the air pocket, natural convection there would increase the rate of heat transfer and reduce the heat transfer resistance of the wall.
Chet
Likes 1 person
Thank you so much! :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
