Question about the Scharnhorst effect
  • Thread starter Thread starter Dmitry67
Dmitry67
http://en.wikipedia.org/wiki/Scharnhorst_effect
I see 2 different interpretations:
1. There is no violation of causality. Light in vacuum is traveling slightly slower then c. Between 2 plates it is traveling faster then light in vacuum but still slightly slower then c
2. c is a speed of light in vacuum, so it is traveling faster then c between 2 plates
I tend to think that 1 is correct... But I am not sure... any ideas?
Einstein did not believe that the speed of light (c) was constant from place to place in a vacuum, as he explained in his 1920 book "Relativity: the Special and General Theory".
http://www.bartleby.com/173/22.html
Einstein said:
In the second place our result shows that, according to the general theory of relativity, the law of the constancy of the velocity of light in vacuo, which constitutes one of the two fundamental assumptions in the special theory of relativity and to which we have already frequently referred, cannot claim any unlimited validity. A curvature of rays of light can only take place when the velocity of propagation of light varies with position. Now we might think that as a consequence of this, the special theory of relativity and with it the whole theory of relativity would be laid in the dust. But in reality this is not the case. We can only conclude that the special theory of relativity cannot claim an unlimited domain of validity; its result hold only so long as we are able to disregard the influences of gravitational fields on the phenomena (e.g. of light).
Please refer to the quote in my sig for a little clarification on his motivation.
Hi Dmitry67! :smile:
I'm with you …
the existence of a speed, c, on which all observers agree is a matter of geometry …
the speed of light is a matter of physics, and has to be ≤ c …
but I'm not sure either. :smile:
I think we need to be a little careful here. First, there is no experimental verification of the Scharnhorst effect. It may not even be possible to verify this: at long wavelengths, quantum mechanics gets in the way of precise speed measurements, and at short wavelengths the approximation of a perfect conductor breaks down. It's entirely possible that there is no physical configuration possible to see this effect - if it's really one part in 1030, or 1035 it's entirely possible that idealizations like "perfect conductor" fail just like idealizations like "rigid rods" fail in SR.
Second, it's certain that QED is not the right theory to give you 35 digits of precision. You'll need the full-blown electroweak theory, and you might even need to worry about GR effects. It's far from clear that the rigorously correct calculation would give the same answer.
Third, it's also far from clear that even if such a thing actually did permit signals infinitesimally faster than c, you could use this to send a signal backwards in time. Such an arrangement would involve two interpenetrating Scharnhorst regions - at a bare minimum, edge effects would have to be considered.
Finally, if you had "Lorentz c" faster than "light c", that would give the photon a mass (not observed), and would permit charge non-conservation (also not observed).
At what speed in who's reference frame?
Actually, can anyone explain that in the context of astrophysical gamma ray delays?
Or 3: c = the speed of light in a vacuum and light travels faster between to conductive plates because the vacuum is modified. In other words the Scharnhorst effect actually changes the value of c locally.
We often see discussions about what QM and QFT mean, but hardly anything on just how fundamental they are to much of physics. To rectify that, see the following; https://www.cambridge.org/engage/api-gateway/coe/assets/orp/resource/item/66a6a6005101a2ffa86cdd48/original/a-derivation-of-maxwell-s-equations-from-first-principles.pdf 'Somewhat magically, if one then applies local gauge invariance to the Dirac Lagrangian, a field appears, and from this field it is possible to derive Maxwell’s...
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
