Question about water weight and pressure
To determine the weight of water needed to burst a circular wine barrel with a diameter of 75 cm, the net upward force on the barrel's top must equal 643 N. The pressure in the tube, initially at atmospheric pressure, increases as water is added, following the formula P = Patm + Pwater(g)(h). The area of the tube is calculated as 7.85e-5 m², while the barrel's area is approximately 0.446 m². Using the pressure-force relationship, the pressure in the tube is found to be 1441 Pa, leading to a calculated force of 0.113 N, which corresponds to about 0.0115 kg of water. Understanding how to apply the area in pressure calculations is crucial for solving this problem accurately.
lyndan
So the question asks:
A circular wine barrel 75 cm in diameter will burst if the net upward force exerted on the top of the barrel is 643 N. A tube 1.0 cm in diameter extends into the barrel through a hole in the top. Initially the barrel is filled to the top and the tube is empty above that level. What weight of water must be poured into the tube to burst the barrel?
I understand that the initially pressure in the tube is Patm before any water has been poured into it and that that pressure will later become P = Patm + Pwater(g)(h) but I can't seem to figure out how to answer the question.
Any help would be appreciated!
Moved to homework help...
Use the pressure vs force equation: p=f/a to relate the force on the top of the barrel to the pressure of water in the tube.
I never done anything with pressures so I might be wrong, but this is what I did:
Area of small tube = 7.85e-5m^2
Area of barrel = 0.446^2
P1=F1/7.85e-5m
F2=643N=P1(0.446m^2)
So P1= 1441 Pa
Then I solved for F1, getting 0.113N which divided by 9.8 gives .0115Kg of water.
I omitted the atmospheric pressure because I have no clue how to use it.
And again, first time I even see the formula for Pressure so I'm possibly wrong (my final answer is pretty weird to be real).
i tried to relate those formulas but i don't know what i am supposed to use as a value for A
Hi lyndan! :smile:
You've probably worked this out by now,
but in case you haven't, you'll need to use A twice …
once for the cross-section area of the tube, and once for the cross-section area of the barrel. :wink:
  • · Replies 37 ·
  • · Replies 19 ·
