QUESTION: Interval of Convergens for a series
In summary: Therefore, the Radius of convergence R = \infty and the interval of convergence is (- \infty, \infty). In summary, the series \sum_{n=1} ^{\infty} \frac{1}{x^2+n^2} has a Radius of convergence of \infty and an interval of convergence of (- \infty, \infty), proven by using the comparison test with \frac{1}{n^2}.
Hummingbird25
86
Hi
I have this series here
[tex]\sum_{n=1} ^{\infty} \frac{1}{x^2+n^2}[/tex]
I need to show that the Radius of convergens [tex]R = \infty [/tex] and the interval of convergens therefore is [tex](- \infty, \infty) [/tex]
My question is to do this don't I use the ratio-test?
Sincerely Yours
Hummingbird25
a_n is the nth term, so:
[tex]\left| \frac{a_{n+1}}{a_n} \right | = \left| \frac{1}{x^2+(n+1)^2} \cdot \frac{x^2+n^2}{1} \right |[/tex]
However, this goes to 1 as n goes to inifinity so this really doesn't help you. What you probably want to do is use comparison test with 1/n^2 to show that it converges for any x.
Hi and thanks for Your answer,
Then by the comparison test:
[tex]\frac{1}{x^2 + n^2} < \frac{1}{n^2}[/tex] ??
Sincerely
Hummingbird25
Thats right, and since [tex]\sum_{n=1} ^{\infty} \frac{1}{n^2}[/tex] converges (by p-series), [tex]\sum_{n=1} ^{\infty} \frac{1}{x^2+n^2}[/tex] converges since every term is smaller.
FAQ: QUESTION: Interval of Convergens for a series
What is the interval of convergence for a series?
The interval of convergence for a series is the range of values for which the series will converge, meaning that the sum of the terms in the series will approach a finite number as the number of terms increases.
How is the interval of convergence determined?
The interval of convergence is determined by using the ratio test, which compares the absolute value of the (n+1)th term to the nth term of the series. If the limit of this ratio is less than 1, the series will converge. The values at which the limit equals 1 determine the endpoints of the interval of convergence.
What is the significance of the radius of convergence?
The radius of convergence is half of the length of the interval of convergence, and it represents the distance from the center of the interval to either of its endpoints. It is important because it determines the values for which a power series will converge absolutely.
Can a series have a radius of convergence of 0?
Yes, a series can have a radius of convergence of 0, which means that the series will only converge at the center point of the interval. This occurs when the limit in the ratio test is equal to 1 at both endpoints of the interval of convergence.
How does the interval of convergence affect the accuracy of a series?
The interval of convergence is directly related to the accuracy of a series. The larger the interval of convergence, the more terms can be included in the series, resulting in a more accurate approximation of the function being represented. However, this does not guarantee that the series will converge to the actual value of the function at any given point within the interval.
