Question to aid my science fair research
The science fair project investigates the relationship between skid distance and cone length using paper cones and marbles. The experiment shows a direct correlation between the length of the cone (ranging from 10 to 30 cm) and the skid distance. A key question raised is whether the mass of the cone affects the results, with considerations about the cone's weight relative to the marble's weight. It is suggested that while the cone's mass may influence friction and acceleration, the primary focus should remain on the cone's length. The discussion emphasizes the importance of minimizing variables while exploring these dynamics.
oooo
I am doing a science fair project in which I am trying to find the relationship between skid distance and cone length. In class we used paper cones which were lined up at the bottom of a ramp (as seen in the attached image) and a marble was released. The marble then, after rolling, entered the paper cone and skid distance of the cone was recorded. So, for science fair, I made different length cones between 10 and 30 cm and through my data I saw a direct relationship between the length of the cone and the skid distance. My only question is why does this occur? I need some ideas as to where to start my research, if anyone knows and could help. THANKS!
Is the weight of the paper cone significant when compared to the weight of the marble?
- Warren
I believe that the mass of the cone is less than the mass of the marble, though I have not weighed them. Would that be a good thing to do?
However, I do not want to introduce too many variables. I am mainly focused on the length of the paper cone as opposed to its mass.
You're asking why the effect occurs, aren't you? The mass of cone is certainly relevant; the marble has to accelerate the mass of the cone, and the mass of the cone contributes to greater friction across the table.
- Warren
thank you!
