Questions about the GI Foundry?
  • Thread starter Thread starter Haroon1
The "GI" in "GI foundry" stands for Gießerei-Institut, which translates to Foundry Institute. The sintering cycle in an induction furnace involves the heating process, including heat-up, soak time, and cooldown. Swarf refers to metal shavings and debris from machining, while scrap encompasses a broader range of waste, including defective parts. A band saw cutting machine features a continuous blade that allows for straight cuts, distinguishing it from other saw types. Understanding these concepts is essential for those involved in metal casting and machining processes.
Haroon1
Hi :smile:
All the below Questions are related to the GI Foundry. Please clear my doubts.
1. What does the "GI" stand for in a "GI foundry" which is otherwise known as Ferrous Foundry?
2. What is the 'Sintering Cycle" of an induction furnace?
3. What is the difference between swarf and scrap?
4. What is a band saw cutting machine?
Thanks.
GI = Gießerei-Institut (GI) der RWTH Aachen
Gießerei-Institut = Foundry Institute
Most of the research seems to be involved in casting of metals, i.e. from liquid to solid.
Sintering might refer to ceramics or powder metals, and the sintering cycle would refer to the time during with the heating takes place - from heat up through soak time to cooldown/quench.
Swarf = turnings, chips, or filings, are shavings and chippings of metal — the debris or waste resulting from metalworking operations. Swarf can be recycled.
Scrap also includes waste besides Swarf and defective parts or broken pieces of parts. Basically scrap/swarf can be remelted and put back in the stream. Care must be taken to ensure that scrap/swarf is 'clean', i.e., free of cutting/machining fluids.
A band saw uses a continuous blade/ribbon or band, hence the name band saw.
http://en.wikipedia.org/wiki/Band_saw
The benefit of the band saw is a straight cut (as opposed to a circular saw) and continuous direction of the teeth (as opposed to a jigsaw with alternating direction of teeth).
Thanks a Million!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
