Questions on Internal Energy and Specific Heat Capacities
The discussion revolves around questions related to internal energy and specific heat capacities, with a focus on calculating thermal capacity, the time to boil water in an electric kettle, and energy required to remove a water molecule from boiling water. Specific heat capacities for water, ice, lead, and copper are provided, along with latent heat values for ice and water. The user seeks clarification on thermal capacity calculations and the relationship between latent heat of vaporization and condensation. Responses indicate a need for step-by-step guidance, particularly for the kettle's boiling time and the energy calculations. The conversation highlights the importance of understanding definitions and concepts in thermodynamics.
Auron87
I've got a set of questions based on internal energy and specific heat capacities and things. I could just do with a bit of help on some of them. Just a push in the right direction will probably do! Thanks.
Specific heat capacity of water = 4200 J/kg/K
Specific heat capacity of ice = 2100 J/kg/K
Specific heat capacity of lead = 130 J/kg/K
Specific heat capacity of copper = 390 J/kg/K
Specific latent heat of fusion of ice = 330 kJ/kg
Specific latent heat of vaporisation of water = 2.3MJ/kg
1. Calculate the thermal capacity of an object that contains 950g of copper and 700g of lead.
2. An electric kettle is rated as 2.5kW. The thermal capacity of the kettle is negligible and then kettle is filled with 1.2kg of water at 15 degrees C.
Calculate (a) the time taken for the kettle to bring the water to the boil and (b) the mass of the water boiled away in 4 mins.
3. The mass of 1.0 mole of water is 0.018 kg. Estimate the energy required to remove a molecule of water from the surface of boiling water. (Avogadro constant = 6.02 x 10^23 mol^-1).
And also if something is as steam and is condensing to water then wuold the specific latent heat of it be the same as the latent heat of vaporisation of water?
Thanks again!
There isn't a whole lot of room to "hint" at these --- you understand the definitions or you don't --- these are "What color was George Washington's white horse?" type questions. One step at a time, and show where you're getting lost.
Well for question 1 I don't really understand what it means by thermal capacity but what I think I would do is work out the heat capacity by multiplying the specific heat capacity by the mass and then add the two together.
For the 2nd question I think I've done part (a) although I'm not sure that it is correct. This is what I did:
2.5 kW = 2500 J/s
dQ = mc(dT)
= 1.2 x 4200 x 85
= 428400
428400/2500 = 171.36 secs
Part (b) I don't really know where to start with
The 3rd question I am very confused about and again don't really know where to start.
1) Yup.
2) Good so far. b) Step at a time: decide whether 4 min. is total time, or time elapsed after you get to boiling temp.; then, 4min. or 4 min. - your 171 sec. times burner power equals total energy you've put into vaporizing water.
3) How much water are you evaporating/vaporizing? 1/A moles?
Enthalpy of vaporization is minus enthalpy of condensation, or vice versa.
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
  • · Replies 16 ·
