Reaction force be 0 at top of circular path swing?
At the top of a vertical circular swing, the reaction force of the bucket on the water can be zero because the minimum centripetal force required is equal to the weight of the water. This occurs specifically at the top of the swing, where the centripetal force is at its lowest due to the swing's energy distribution. At the bottom of the swing, the reaction force must counteract gravity and provide additional centripetal force, while at other points in the swing, the forces are not purely vertical. The water is effectively in free fall at the top, which explains the absence of a reaction force at that point. Understanding these dynamics clarifies how forces fluctuate throughout the entire swing.
opne
Hi, I have a question about a bucket filled with water being swung in a vertical circular path.
I'm wondering why at the top of this swing, the reaction force of the bucket on the water can be 0? (ie. why is the minimum centripetal force required only the weight of the water?)
Then, why can the reaction force only be 0 when the bucket is at the top of its swing?
Further, how else does the reaction force fluctuate throughout a full 360 swing?
F=mv^2/r
mv^2/r = mg + R
Minimum v^2 = rg
R= 0
mv^2/r = mg ... but I have no clue whyThanks.
You have to be careful what you mean by minimum. Minimum with respect to varying what and holding what constant?
For a given constant swing rate, the centripetal force is constant.
For a given total energy, the swing rate is least at the top, so the centripetal force is least there.
If you mean minimum across all energies for which the water does not fall out: If the centripetal force required at the top of the swing were any more than the weight of the water then you could swing the bucket with a little less energy without the water falling out.
At the bottom the reaction force has to counter gravity as well as provide the centripetal force. For any position except top or bottom, the centripetal force is not vertical, so something other than gravity must contribute to it.
If the energy is fixed, write an expression for the tangential speed as a function of the angle.
Ah yes! This clears things up thank you.I guess a better question would be, how can the reaction force of the bucket on the water suddenly become 0/stop existing, even though the water is still inside the bucket, and so presumably exerting a force on the bucket?
Or is there no longer a force of the bucket, and the water is in free fall at the top?
Thank you!
Yes.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
