Recomposing trig and hyp functions
  • Thread starter Thread starter Marin
    Functions Trig
The discussion focuses on recomposing expressions involving arcsine and hyperbolic functions, specifically arcsin(cosx), arsinh(coshx), arcsin(coshx), and arsinh(cosx). The user seeks clarification on how to derive square root expressions for the first two and expresses uncertainty about the last two without resorting to complex numbers. It is noted that arcsin(cos(x)) can be simplified using the relation cos(x) = sin(π/2 - x), leading to arcsin(cos(x)) = π/2 - x. For hyperbolic functions, the Pythagorean identity cosh²(x) - sinh²(x) = 1 is highlighted, and there's a suggestion to use complex numbers for mixed types. The conversation emphasizes the differences between trigonometric and hyperbolic function compositions.
Marin
192
Hi!
I want to recompose the expression of the form:
arcsin(cosx) , arsinh(coshx), arcsin(coshx), arsinh(cosx)
but I can't figure out how this is supposed to work :( I expect square root expressions for the first two and I'm not sure one can recompose the last two without using complex numbers.
Could someone please help me in a way? Thanks in advance :)
Mathematics news on Phys.org
Firstly understand that problems of the form arcsin(cos(x)) are quite different to problems of the form cos(arcsin(x)).
For the first type simply use the "complement" relation that cos(x) = sin(Pi/2-x) to write,
\sin^{-1}(\cos(x)) = \sin^{-1}(\sin(\frac{\pi}{2}-x)) = \frac{\pi}{2}-x
{or 90-x if you prefer to use degrees}.Since you "were expecting square root type expressions" I assume you where actually thinking about the opposite type of problem such as cos(arcsin(x)).
Here you need to use the relation that \cos(x) = \sqrt{1-(\sin x)^2}
Making this substitution you get,
\cos(\sin^{-1}(x)) = \sqrt{1-(\sin (\sin^{-1} x))^2}
= \sqrt(1-x^2)
Thanks, uart!
And what about the hyperbolic functions? There is no Pythagoras for hyperb. functions, is there?
And the mixed type in the field of the real numbers is quite unclear to me :(
For hyp-trig functions the equivalent of the pythagorean relation is
\cosh^2(x) - \sinh^2(x) = 1Yeah for the mixed ones I thinked I'd have to go complex and use cosh(x) = cos(i x) and sinh(x) = -i sin(i x). Maybe someone else can offer a better solution there.
So it's:
\cosh(\arsinhx)=\sqrt{1+\sinh(\arsinhx)}=\sqrt{1+x^2}
() is suppose to have \arsinhx inside - what's wrong with the Latex typing it?
And what do we do when we have: arsinh(coshx) hmmmm?
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation has no solutions with positive integers if It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
