Reflection of sound wave in an open organ pipe
Sound waves in an open organ pipe create standing waves through the superposition of original and reflected waves, despite the absence of a physical barrier at the open end. The open end allows air particles to vibrate, causing oscillations that generate waves outside the pipe. When pressure inside the pipe is low, air from outside rushes in, creating a reflected wave traveling back into the pipe. Conversely, if pressure inside is high, air moves outward, also generating a wave that travels in the opposite direction. This dynamic maintains constant pressure at the open end, facilitating the formation of standing waves.
vcsharp2003
How and why does a sound wave get reflected from the open end of an organ pipe?
None
I know that standing waves form in an open organ pipe. Since, standing waves can only form from superposition of original wave and reflected wave, so there must be a reflected wave in an open organ pipe. But I fail to understand how sound wave can reflect at the open end of organ pipe.
Why does this surprise you? It will be easier to address your question if you give the reasoning.
My understanding is that the sound wave should travel through the open end since there is no barrier. The air particles in a sound wave are vibrating parallel to wave direction. At the open end, the air particles vibrating should cause the air particles just outside the pipe to also start oscillating resulting in a wave outside the tube. The open end cannot exert a force on the air particles just inside the pipe to cause a reflected wave unlike a closed end.
Consider this: At the open end, pressure is approximately constant. If there was just a wave towards the open end, there is no way that pressure could be maintained constant.
Likes vcsharp2003
So, when pressure is low just inside the open end then air from outside would rush to inside the open end causing particles to move just inside the open end resulting in a wave traveling in opposite direction to original wave.
If pressure is high just inside the tube compared to outside then air would rush towards the outside that causes air particles to move just inside the open end resulting in a new wave/ disturbance inside the pipe in opposite direction to original wave.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
