I Reflectivity of Pure Metals in Vacuum
The discussion highlights the difference in reflectivity between pure metals and their oxidized forms, particularly focusing on aluminum in atmospheric conditions versus vacuum. It emphasizes that pure aluminum, as used in the James Webb telescope, would be highly reflective in a vacuum but is subject to oxidation on Earth. The conversation raises the need for reliable data on the reflectivity of pure metals like calcium, magnesium, and titanium in vacuum conditions. Participants express concern over the accuracy of sources that conflate the reflectivity of pure metals with their oxidized states. The topic underscores the challenges of conducting scientific investigations in atmospheric conditions while seeking precise reflectivity data.
jms4
All data I see online about reflectivity of metals is about aluminum in the atmosphere meaning oxidized aluminum, but pure aluminum in vacuum in case of the James Webb telescope would also be extremely reflective but building it on Earth means it's going to get oxidized, similarly there are a lot of pure metals out there which would be very reflective in vacuum such as calcium or magnesium or titanium if they wouldn't oxidize in the atmosphere. Is there any data about most reflective materials pure materials in vacuum?
Do you have an example source you can provide? I feel like there may be a disconnect between the question and the answers you are finding, as a quality source should be giving you exactly what it tells you it is giving you. If it says reflectivity of Al it should be reflectivity of Al, not Al2O3. There are work-arounds to the problem of working in the atmosphere, though they may be too cumbersome to bother with for anything but a scientific investigation.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
