Regarding a block and an inclined plane
The discussion centers on solving a physics problem involving a block on an inclined plane, where a constant force is applied parallel to the slope. The key equation for acceleration is derived as ax=(P/m)-g(u*cos[theta]+sin[theta]). Participants express frustration over vague textbook explanations and the lack of examples for similar scenarios. Clarifications are provided regarding the forces acting on the block, including gravity, friction, and the applied force. The conversation concludes with the user gaining understanding of the concepts involved in the problem.
richpetty888
Person pushing a block with mass m on an inclined plane with angle [theta]. The friction coefficient is u. If the force applied is constant and parallel to the slope of the plane, show that the acceleration ax of the block in the direction of motion can be expressed as :
Force = P
Mass = m
Gravity = g
Friction coefficient = u
Force = mass*acceleration
First I drew the free body diagram, but I'm seriously lost coming up with equations. My book has nothing but vague allusions to formulae (with no examples whatsoever), and the internet is rife with blocks sliding down planes, but barren regarding blocks being pushed up them.
Furthermore, the problem does not give information concerning the distance the block is pushed, nor does it include that measure in the "final answer" I'm supposed to solve for, but I thought distance was essential to measuring acceleration.
Anyways, I'm lost here, folks. My physics acumen is lacking, to say the least, and the fact that my book asks these little "concept" questions while seeming deliberately wordy and mystifying only serves to frustrate me further.
Help please.
Force = P
Mass = m
Gravity = g
Help please.
The distance doesn't matter here. You have three forces acting on the block. One is the force of gravity. One is the force from the plane. One is the force of the person pushing. All of these add up to a single total force that gives a certain acceleration to the block.
What do you know about the co-efficient of friction? Have you got any equations for that?
Cheers -- sylas
Ok, I've got the force of gravity equaling m*(-g)*sin[theta]. Friction doesn't apply to that one, so no "u".
Then, pushing force = u*mg*cos[theta].
Finally, force of the plane = P*(u*m).
If I add them together (?) I get P(u*m)+(m*g)(ucos[theta]-sin[theta])
I seem to have the last part correct, only everything before it is off. There is undoubtedly an error in the equations I just listed, but they're all I have. I guess an explanation of a little theory here might help me. Why am I subtracting the g(ucos - sin) part, and how do I get there? How do I get rid of the u in the first part?
I think I'm using equations for work instead of equations for forces, which might explain the extra variables.
you seem to have mixed up the pushing force and the force of the plane.
The pushing force is just P.
The size of the force of the plane (I would call it friction force) is indeed u*mg*cos(theta). It's working against the direction of movement, so it needs a minus sign.
If you add them and use F=ma you get the right answer
Thank you, sylas and willem! I understand it now.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
