Relative Wind Problem (Modern Engineering Mathematics, 5th)
A cyclist traveling east at 8 km/hr perceives the wind coming from the north, and when his speed doubles, it appears to come from the northeast. The problem involves using the relative wind equation, which states that the perceived wind equals the actual wind minus the cyclist's velocity. The cyclist's velocity is represented as a vector (16, 0) and the perceived wind as a vector dependent on the actual wind's components. After solving the equations, the actual wind velocity is determined to be approximately 11.31 km/hr with a vector of (8, -8).
SubZer0
A cyclist traveling east at 8 km/hr finds that the wind appears to blow directly from the north. On doubling his speed it appears to blow from the north-east.. Find the actual velocity of the wind.[/B]
Wind(relative) = Wind(Actual) - Velocity(cyclist)
I am completely stuck on this. I do know that there is a (16, 0) vector for the velocity of the cyclist, and a vector of -a(cos(45 deg), sin(45 deg)), which represents the relative, or perceived wind.
Slotting this into the relative wind equation,
Wind(r) = Wind(a) - Vel(cyclist)
-a*cos(45 deg) = Wx - 16
-a*sin(45 deg) = Wy
I'm not sure if this is even on the correct track.
Any trips highly appreciated.
It is.
You just need to write the corresponding equations for the 8km/h case.
haruspex said:
It is.
Thanks heaps for the reply, haruspex. I think I just needed that little confidence boost you gave me to help solve the problem.
So now I have the full set of equations:
-a*cos(45 deg) + 16 = Wx
-a*sin(45 deg) = Wy
Wx = 8
Wy = b
Slotting Wx into the first equation;
8 = 16 - a*cos(45 degrees)
a = 11.3137
Slotting a into (2), gives:
Wy = -11.3137*sin(45 degrees)
Wy = -7.999 (approx 8)
Therefore, actual wind velocity has vector of (8, -8). Magnitude, of sqrt(64+64) = 11.31km/hr
Thanks, haruspex!
Looks right.
