Removing "Foreign" objects from Excel notebook file?
  • Thread starter Thread starter WWGD
    Excel File
A user is experiencing difficulty removing a persistent "picture-like" object from an Excel file, specifically a white rectangle with the text "United StatesStates." Attempts to delete the row containing the object have been unsuccessful, and the user encountered a '403' error when trying to scrape data directly from a webpage into Excel. Suggestions include clicking on the image to delete it, but the user reports that right-clicking did not work. They ultimately copied previous rows into a new sheet for data cleaning. The discussion also touches on the benefits of using newer versions of Excel, particularly for data science, as they offer improved functionality and compatibility. Additionally, there is a mention of the British company Pivigo, which is noted for its corporate finance activities, although the user has not worked with them directly.
WWGD
TL;DR Summary
Having trouble deleting "Foreign Object" picture-like from an Excel 2007 file.
Hi,
I'm having trouble dealing a "picture-like" object that I copied from a webpage (.html) file. It is the larger white rectangle in rows 194-195, that reads "United StatesStates"
It just doesn't go away when I delet the the row. I tried to scrape the file directly into Excel from the site , but got a '403' error message (forbidden). How can I delete the row without affecting other files?
Thanks.
Computer science news on Phys.org
Try clicking on the picture and hitting delete.
Office 365 Family at GBP80 a year (not sure how much it is in US) is worth every penny to me.
Thank you, though I'm not sure I understand you. I'm using Excel 2007. You mean the newer versions
will (more likely) have a way of addressing this issue? And, sorry, r-clicking did not work. I just copied all previous rows into a new sheet. Hey, can't overdo the practice of data cleaning.
On a separate note, any chance you've heard of this British company Pivigo? Have you heard anything about it?
Probably not, but newer versions play a LOT better with all kinds of connections, as well as do a lot of other stuff better. If you are at all serious about data science (or anything really) on Excel you need to be on the current version.
Glad you got it sorted.
Yes, haven't worked with them personally but I know they are doing stuff with clients I know. Looks like there was some corporate finance activity this Spring.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
