Required force for sphere start rolling
The discussion centers on the force required to initiate rolling motion in a sphere compared to a cube on the same surface. It is established that the force needed to slide the cube equals the static friction force, μs⋅m⋅g. For the sphere, the required force to start rolling is theorized to be less than this static friction force, as it also involves rolling resistance. The conversation emphasizes the importance of considering torques at the point of contact with the surface to determine the applied force necessary for rolling. Understanding these dynamics is crucial for accurately calculating the forces involved in rolling motion.
eyeweyew
What is the required applied force to the center of mass of the sphere for it to start rolling on a surface?
μ[SUB]s[/SUB]⋅m⋅g
Assume there are two objects on the same surface, one is a cube and the other is a sphere. Both objects have the same mass m. The required applied force to the center of mass of the cube for it to start sliding should be equal to static friction force: μsmg.
But what is the required applied force to the center of mass of the sphere for it to start rolling? I assume it should be less than static friction force: μsmg?
This depends on rolling resistance, not friction (apart from that friction needs to be large enough for the ball to roll rather than slide).
Consider torques about the point of contact with the surface. What torques are there?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
