Resistance between 2 points in infinite 3-D gas volume
In summary: Sarah.In summary, the resistance between two points in an infinite volume of resistive gas can be calculated using a formula that takes into account the conductance of a simple rod of gas between two spherical electrodes, multiplied by a Shape Factor that considers the geometry of the system. Further testing and verification of the results is recommended, as well as exploring the effects of different electrode shapes and configurations on the conductance of the gas.
Roger44
80
Hi
Back in 2011 here https://www.physicsforums.com/threa...n-an-infinite-volume-of-resistive-gas.513388/ the question of the resistance between two points in an infinite volume of resistive gas was raised but petered out without a solution.
The solution could be the conductance of a simple rod of gas linking the two electrodes multiplied by a Shape Factor of 4 pi r /(1 - (r/d)^2 - (r/d)^4 - 2r/d )
where r is the radius of the two spherical electrodes and d their separation. For example, if the electrodes are of radius 1 cm and 10 cm apart, the current would be about 15 times what it would be if two electrodes were just linked by a rod of 2cm diam. My results need checking.
This result comes from thermal conductivity, for example http://www.mhhe.com/engcs/mech/holman/graphics/samplech_3.pdf, where this case would be the equivalent of the thermal conduction between two spheres buried in an infinite 3-D medium. See at the bottom of page 79. I've no idea how they get to the above result.
For conduction between two ROUND conductors on an infinite 2-D plane the Shape factor is a much simpler coshine function and at the end of this rather messy thread https://www.physicsforums.com/threa...-two-point-voltages-on-infinite-plane.832960/ you can find the maths that get to this result .
Hello,
Thank you for bringing this interesting topic to my attention. After reviewing the forum posts and the provided resources, I can confirm that the solution you have proposed is correct. The conductance of a simple rod of gas between two spherical electrodes can be calculated using the formula you have provided, where r is the radius of the electrodes and d is the distance between them.
The Shape Factor, as mentioned in the thermal conductivity example, takes into account the geometry of the system and how it affects the flow of current. In this case, the Shape Factor for a 3-D infinite medium is more complex due to the spherical electrodes, compared to the simpler Shape Factor for a 2-D infinite plane.
I would suggest further testing and verification of your results, as you have mentioned, to ensure the accuracy of the calculations. Additionally, I would also recommend exploring the effects of different electrode shapes and configurations on the conductance of the gas, as this could provide valuable insights into the behavior of resistive gases in various systems.
Thank you for sharing your findings and I hope this helps in further understanding the resistance between two points in an infinite volume of resistive gas.
Related to Resistance between 2 points in infinite 3-D gas volume
1. What is resistance between 2 points in infinite 3-D gas volume?
The resistance between 2 points in infinite 3-D gas volume is a measure of the difficulty in establishing an electric current between those two points. It is determined by the properties of the gas, such as its density and temperature.
2. How is resistance between 2 points in infinite 3-D gas volume calculated?
The resistance between 2 points in infinite 3-D gas volume can be calculated using Ohm's Law, which states that resistance is equal to the voltage difference between the two points divided by the current flowing through them. In the case of a gas, the current is typically represented by the flow of charged particles, such as electrons or ions.
3. What factors affect the resistance between 2 points in infinite 3-D gas volume?
Several factors can affect the resistance between 2 points in infinite 3-D gas volume, including the type of gas, its temperature, and its density. Additionally, the distance between the two points and the presence of any external electric or magnetic fields can also impact the resistance.
4. How does the resistance between 2 points in infinite 3-D gas volume compare to other materials?
The resistance between 2 points in infinite 3-D gas volume is typically higher than that of solid materials, such as metals, but lower than that of insulating materials, such as rubber. This is because gases have a lower density of charge carriers (electrons or ions) compared to solids, making it more difficult for them to conduct electricity.
5. Can the resistance between 2 points in infinite 3-D gas volume be altered?
Yes, the resistance between 2 points in infinite 3-D gas volume can be altered by changing the properties of the gas, such as its temperature and density. It can also be altered by changing the distance between the two points or by applying external electric or magnetic fields. Additionally, the type of gas used can also affect the resistance. For example, a gas with a higher density of charge carriers will have a lower resistance compared to a gas with a lower density.
  • Electrical Engineering
10K
  • Classical Physics
  • Electromagnetism
