Connecting a resistor in parallel with a voltage source primarily results in heat generation without impacting circuit analysis, unless heat is a necessary factor for the circuit's function. An ideal voltage source maintains its voltage regardless of the current supplied, while an ideal current source adjusts its voltage to ensure a constant current flow. The presence of the resistor does not influence the overall circuit behavior in these scenarios. Circuit diagrams can clarify the relationships between voltages and currents. Understanding these principles is essential for accurate circuit analysis.
#1
hquang001
31
TL;DR Summary
Why in a circuit, when a resistor is connected parallel to a voltage source, or in series with current source, we can get rid of that resistor ?
Because in those situations the resistor only generates heat. The resistor does not affect the way the rest of the circuit is analysed, unless the circuit is a heater or needs the heat source.
An ideal voltage source will maintain the ideal voltage, no matter how much current it must supply.
An ideal current source will provide sufficient voltage to maintain the ideal current, no matter how much voltage is dropped across the resistor.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi Guys
We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns.
What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design.
Any help will be appreciated.
Thanks.
edit: even same wire diameter and coil was wounded by a...
