- #71
jbriggs444
- 12,925
- 7,591
If you throw the mass off continuously there is not much controversy to be found. No one in their right mind would throw out the reaction mass at more than a single relative velocity. You use up the energy in an incremental bit of fuel and you use 100% of that incremental energy to expel 100% of the incremental expended fuel at the maximum velocity that energy can allow.bob012345 said:I thought we were discussing throwing all the reaction mass off at once vs. continuous with a number of discreet steps as a bridge. For the case of the ratio ##\frac{m_f}{m_r} = 1##, it all depends on whether there is one reaction mass ##n = 1## or ##n > 1##. What you say is only true for equal reaction mass and dry mass and only one reaction.
In my equation, every reaction occurs in its own inertial reference frame different from the previous reaction reference frame by the additional delta##v## kick of the last reaction. The total accumulated ##v_f## is in relation then to the initial reference frame taken as at rest.
You would not, for instance, use your liquid hydrogen and liquid oxygen to power a fuel cell, use the energy from the fuel cell to power an ion rocket and then dribble the waste water out the back at zero relative velocity. That would be an example of throwing your reaction mass out at two different exhaust velocities. It would be a daft thing to do. You get much better performance by expelling the waste water out the back. So nobody does the daft thing.
If you are handling the fuel in discrete chunks, you would ideally want to do much the same thing. You would want to use up all of the energy in a chunk of fuel and expel all of the expended fuel in that chunk at a single velocity so that all of the expended fuel in that chunk moves off as a blob rather than as an expanding cloud. You could save energy that way (at what would probably be an intolerable expense of practicality).
The Tsiolkovsky rocket equation does not contemplate such an approach. Nor does merely stating "I am going to burn all my fuel at once" necessarily entail such an approach. But if you do burn your fuel all at once, you should pay attention to the freedom you have to choose how to distribute the exhaust velocity of the material you are expending in the impulsive burn.
