Rotating Earth as an inertial frame
In summary, the principle of relativity states that any frame of reference is equally valid for describing phenomena and the laws of physics, regardless of its motion. However, in special relativity, rotating frames of reference are not allowed and the laws of the universe only apply to frames moving at a constant speed. In general relativity, frames of reference can behave differently, but the laws of the universe only hold locally and may not apply to distant objects. The apparent contradiction of superluminal speeds observed from a rotating Earth frame of reference can be resolved by understanding that these are coordinate velocities and do not have physical significance. Additionally, in both SR and GR, there are scenarios where objects may appear to be moving faster than the speed of light, but
  • #71
RandallB said:
As best as I can Tell GR requires that an Observer that observes rotations; can use any rotating frame of reference with themselves at the center of rotation they Like to simplify how something is observed.
What do you mean by "can use"--are you implying the observer can't use other coordinate systems where they aren't the center of rotation? As I've asked before, do you understand that as far as making physical predictions goes, anyone can use absolutely any coordinate system whatsoever? For example, an inertial observer in SR has no obligation to use their own rest frame when making predictions, they could just as easily use a frame where they are moving at 0.99c.
  • #72
RandallB said:
Option one:
Yes, in GR you can use absolutely any coordinate system you choose.
GR does not require an observer to be at the center of rotation.
RandallB said:
But cannot be required to hold such a selection as “the preferred” rotating frame of reference.
Correct, no coordinate system (frame of reference) is preferred over any other. That is why you can use anyone you choose.
RandallB said:
Thus if an alternate item of is considered for observation and the same “non-preferred” frame of rotation is continued to be used – then FTL “coordinate” violations should be expected as possible.
Yes, timelike worldlines may have coordinate speeds > c in some coordinate systems.
RandallB said:
Option two:
I cannot tell if you are. saying GR is allowing the defining of a “preferred frame of rotation”.
No, there is no preferred coordinate system.
RandallB said:
If so it would seem an observer could be defined not only at the center of rotation but also at any radius from the center of such a preferred frame of rotation.
I don't follow. Why would the freedom to choose an observer's distance from the center of rotation imply that a frame is prefered?
If anything, I would think the opposite would be true: any required restriction to a coordinate system would define a preferred set of frames - those that fulfilled the requirements. I think you have this backwards.
RandallB said:
As a “preferred frame” it should not see FTL events due to rotation. .
There is no preferred frame in GR.
RandallB said:
Under the Option one understanding of GR the OP question has no standing.
Under the Option two understanding of GR I do not see how anyone has yet to resolve the OP question.
I would say that your option 1 is closer to correct, with the only modification being that there is no restriction on coordinate systems in GR, including no restriction on the location of observers.
RandallB said:
I don't know how to make the question any simpler.
Thanks for the attempt. I hope my responses answered your question.
  • #73
Well I guess that is close enough for me. As I could not see how option 2 could be the case. And certainly under the option 1 (mine or as refined by you) it is clear the OP problem is not a issue for GR.
The only part that I do not quite get is how a GR observer can assume a frame rotation centered somewhere else than at their own location.
1) It seems like requiring information from a second observer – where SR; for example, requires using just one frame of referance at a time.
2) Plus what little math I've seen on rotating GR applications do not seem to use rotations dislocated from the observer in used (seems like defining two points of rotation with one at the observer point holding an alignment to the a distant point of rotation).
But as I said before I don't know GR applications that well especially related to rotating systems – not important that my understanding get that advanced, it may be buried inside background independence anyway.
Thanks for your input; I think we have over killed the OP issue here.
  • #74
1) It seems like requiring information from a second observer – where SR E.G. requires using just one.
Once again, do you understand that even in SR it is merely a matter of linguistic convention that we refer to an observer's rest frame as "their" frame, that there is absolutely nothing stopping an inertial observer from using an inertial frame where they are moving at 0.99c in order to make physical predictions?
  • #75
atyy said:
With this in hand, would you like to comment on my guess? I suspect my guess wasn't right, because to answer Tam Hunt's question, shouldn't the worldline at large radii be timelike?
Your guess was exactly correct. The time coordinate is spacelike at large radii, and a massive object's worldline must always be timelike. Therefore, no object can be "at rest" in these coordinates at large radii.
  • #76
D H said:
[quote="JustinLevy]Please be careful what you say here.
Locally they are the same. If a local lorentz frame has a metric with diagonal -1,1,1,1 at the origin, then so too does the origin in a rotating system defined with the origin following a geodesic.
A caveat: I am a GR potzer. That said, what you just said appears to conflict with my understanding of the Born metric for a rotating frame. For example, see http://arxiv.org/abs/gr-qc/0305084 equation (43) (pdf page 22).[/QUOTE]
Well, yes, due to using non-rectilinear coordinates the metric isn't diagonal -1,1,1,1. I guess I should have just said the metric is the same locally at r=0 for that rotating frame and an inertial frame.
For instance if you look at the equation you referenced, setting [itex]\Omega=0[/itex] would be an inertial frame. At r=0, the metric is the same regardless of the value of omega. So the inertial frame and rotating frame are the same locally.
If I'm somehow misunderstanding something, please do let me know.
  • #77
JustinLevy said:
D H said:
Locally they are the same. If a local lorentz frame has a metric with diagonal -1,1,1 at the origin, then so too does the origin in a rotating system defined with the origin following a geodesic.
Thanks. I wasn't talking about r=0. I was implicitly talking about non-zero distances, such as the distance to a quasar. Or at least the radius of a ring laser gyroscope. Speaking of which,
Tam Hunt said:
DH, I'm going a little beyond Wikipedia here. How does one distinguish between an inertial frame and a rotating frame of reference? And please don't appeal to the fixed stars, which suggests instantaneous action at a distance.
A Foucault pendulum or a even better, a set of three orthogonal ring laser gyros will do exactly what you asked. In fact, spacecraft do exactly this. One of the myriad pre-launch checks performed by spacecraft avionics is to answer the question "do my inertial measurement units report that the vehicle is in the expected non-inertial frame?" The accelerometers should report that the vehicle is accelerating upward at about 9.8 meters/second2 and the gyros should report that the vehicle is rotating at 2*pi/sidereal day about the Earth's rotation axis. Failure to detect these known conditions scrubs the mission.
