Rotational Kinetic Energy of Cl2?
The discussion revolves around calculating the rotational kinetic energy of a chlorine (Cl2) molecule, modeled as two point masses rotating about their center of mass. The user initially attempted to use the kinetic energy formula but faced issues with Web Assign indicating an error. The correct approach involves using the moment of inertia for a diatomic molecule, leading to the formula Erot = 1/2 Iω², where I is derived from m(d/2)². After some confusion regarding the calculations, the user clarified the correct moment of inertia and successfully resolved the problem. The thread highlights the importance of understanding rotational dynamics in molecular physics.
XianForce
In a crude model of a rotating diatomic molecule of chlorine (Cl2), the two Cl atoms are 2.00 10^-10 m apart and rotate about their center of mass with angular speed ω = 3.80 10^12 rad/s. What is the rotational kinetic energy of one molecule of Cl2, which has a molar mass of 70.0 g/mol?
1/2 * m * v2 (Kinetic Energy)
v/2 * KB * T (Internal Energy of a molecule)
I attempted to use the equation for kinetic energy, substituting r * ω for v, but my web assign says that this is wrong. Nothing like this was taught in class and the book does not say much, so I'm at a loss for where to go.
The rotational energy of a rigid body (like the Cl2 molecule) is Erot=1/2 Iω2, where I is the moment of inertia and ω is the angular speed of rotation.
The Cl2 molecule can be considered as two point masses d distance apart, rotating around a bisector of the connecting line. So the moment of inertia is 1/2 md^2.
There are two mutually perpendicular axis of rotation so the molecule has got two rotational degrees of freedom.
ehild
So basically: 1/4 * 1 mol /(6.022 * 1023) * (70 * 10-3) kg/mol * (780 m/s)2 = 1.768 * 10-20 J , right? But Web Assign keeps telling me that's wrong, so where am I making the mistake?
Explain your calculation. What is that 780 m/s?
ehild
Nevermind, I figured it out. It's m (d/2)^2, not 1/2 * md^2
Well done!
ehild
