Rubber Band Fumes: Is My Cake Inedible?
Leaving a rubber band around a cake tin while baking can lead to concerns about toxic fumes and residues from the rubber. Experts suggest that rubber can produce harmful substances when heated, making the cake potentially inedible. It is recommended to discard the cake and thoroughly clean the cake tin to remove any burnt residues. Additionally, a deep clean of the oven may be necessary to eliminate any lingering odors from burnt rubber.
NicYeom
I just baked a cake, and accidentally left a rubber band around the cake tin (which was holding the greaseproof paper in place). Is the cake inedible due to fumes given off by the rubber band?? Thanks :)
Chemistry news on Phys.org
Rubber can produce toxic fumes/residues so I would throw the cake away and make sure all the burnt residue is removed from the cake tin.
See below
https://www.physicsforums.com/threads/are-fumes-from-burned-rubber-bands-toxic.993641/
Likes jim mcnamara and NicYeom
Actually - no matter the toxicity - I doubt the cake is edible. Unless you like things that stink of burnt rubber.
Likes HAYAO and pinball1970
You should throw the cake away, but the oven also needs a good cleanup, maybe even an empty burn if a good nose calls it.
Likes pinball1970 and Tom.G
I came.across a headline and read some of the article, so I was curious. Scientists discover that gold is a 'reactive metal' by accidentally creating a new material in the lab https://www.earth.com/news/discovery-that-gold-is-reactive-metal-by-creating-gold-hydride-in-lab-experiment/ From SLAC - A SLAC team unexpectedly formed gold hydride in an experiment that could pave the way for studying materials under extreme conditions like those found inside certain planets and stars undergoing...
  • · Replies 35 ·
