I Russia Claims Laser Weapon Can Destroy Drones: Is it Possible?
  • I
  • Thread starter Thread starter peetm
    Drones Laser
Russia claims to have developed a laser weapon capable of destroying drones from a distance of 1,500 km, though details remain scarce. The feasibility of such a weapon is questioned due to potential atmospheric scattering and energy absorption challenges. While theoretically possible with advanced targeting and large apertures, practical implementation may not occur within the foreseeable future. The discussion highlights implications for satellite vulnerability, particularly for Elon Musk's satellite constellation, which may require protective measures against laser threats. Overall, the concept raises significant technical and strategic considerations in modern warfare.
Science news on Phys.org
It would be difficult, but with a large enough aperture and suitable targeting mechanisms, you could cook a satellite in 5 seconds and render it space junk.
I don't expect to see such a machine in my lifetime.
It would create an interesting problem for Elon. The exact methods he is using to keep his constellation from being a nuisance to astronomers would tend to make his satellites more vulnerable to such a laser.
Against a laser, you would want reflective surface. But a dark surface that can take the heat would work as well. Communication satellites could be readily hardened. Optical satellites would be a different matter.
I was disappointed when the Airborne Laser was cancelled:
https://en.wikipedia.org/wiki/Boeing_YAL-1
It seems to fit the bill, with a range of a few hundred km. I'm not sure what the point of 1,800 km would be, as that's much higher than most satellites (but lower than geosynchronous/stationary).
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
