Satellite orbiting the Earth (heat radiation)
The discussion focuses on calculating the mass of a satellite, which is determined to be approximately 750g using the formula for volume and density. Participants express uncertainty about integrating the heat transfer equation, specifically regarding the temperature variable T and the function to integrate. The integration process for heat transfer, represented as dQ = eσAT^4dt, is discussed, with attempts to clarify the limits of integration. Questions arise about the meaning of E in the equation E = mcΔT and its relationship to the satellite's heat radiation. Overall, the conversation revolves around the complexities of heat radiation calculations for a satellite in orbit.
glorfindel1000
Satellite is orbiting earth and is heated by sun to 323 K. To what temperature satellite cools down during its 45 min cycle in shadow? Satellite is 1 m radius and 2 mm thick copper. Emissivity is 0,75. Space temperature is assumed to be 0 K.(hint. Write a formula to heat change in function of time, you have to integrate)
\begin{align*}
\frac{dQ}{dt} &= e \sigma A T^4 \text{ or } \frac{dQ}{dt} = e * \sigma * A * T^4 \\
\text{(maybe)}E &= cm \Delta T \\
A &= 4 * \pi * r^2 \\
\sigma &= 5,67 \times 10^{-8}{\rm W/(m^2 * K^4)} \\
e &= 0,75
\end{align*}
Mass of a satellite is 750g(##m = \rho V = 8,96 \frac{g}{cm^3}\cdot (\frac{4\pi(100cm)^3}{3} -\frac{4\pi(99,9cm)^3}{3}) = \approx 750g =0,75kg##)
I am not sure what to integrate. I solved T there but it seems far stretched
$$T =\sqrt[4]{\frac{dQ}{dt}\frac{1}{e\sigma A}} $$
How to get the function to integrate is basically my problem. I changed that dt to other side
##dQ = e\sigma AT^4dt##
and integrated it from 0 to 2700.
##Q = \bigg/_{\!\!\! 0}^{\,2700}e\sigma AT^4t##
Not really sure if that helps. What to do with Q then?
Use two # characters like # # (minus the space) to delimit an inline latex statement. Use $ $ to delimit a separate block. Below the bottom left of the window you are typing in, there is a link for more latex help. I edited your post to fix latex. Please make sure I did not cause more problems.
I fixed the LaTeX in the relevant equations section as well. Separate equations were running together, which made them confusing to understand.
In your second relevant equation, ##E = mc\Delta T##, what does the ##E## stand for? How is it related to the heat radiated away by the satellite?
