Scientists jumping off the warming train
  • News
  • Thread starter wolram
  • Tags
    Train
In summary, the US Senate Minority Report features the dissenting voices of over 650 international scientists, many current and former UN IPCC scientists, who have now turned against the UN. The report has added about 250 scientists (and growing) in 2008 to the over 400 scientists who spoke out in 2007.
  • #141
drankin said:
Unless you have at least one PhD and are part of the climate science community recognized by the IPCC, you aren't qualified to make such a statement. Here, have some koolaid.
Science community? You mean Climate Change Ufologists Community?
(to be serious, I am trying to find tests to compare and contrast ufology and climatology, but string theory keeps turning up on the ufology column whenever climatology does.)
  • #142
NeoDevin said:
MattSimmons,
As I said, I'm not up to speed on all the topics covered in the blog post you linked to, but one of my friends (who is better informed on the subject than I, I only got into the debate as of this discussion, and am still learning) sent this reply (edited only to remove a name):
Interesting... thanks. I wonder if your friend has done a similar critique of Steve McIntyre of ClimateAudit fame?
  • #143
LowlyPion said:
I'm sorry. Where again is Greenland most substantially located? Are you suggesting that Greenland is not mostly located in the Arctic? Or is the ice in Greenland to be ignored? Perhaps instead the FSU Professor should have had a 4th Grade Geography Lesson? Now maybe the AP Reporter would have confused Arctic ice with Arctic Ocean ice, but wouldn't you have higher expectations for a professor? And just where was Fox's fact checking in criticizing AP?
The article doesn't mention Greenland. Are you saying that the AP reporter said ice over Greenland?
  • #144
I think the problem with the http://www.breitbart.com/article.php?id=D952LKOO1&show_article=1" article is lazy language, such as
"We're out of time," Stanford University biologist Terry Root said. "Things are going extinct."
That said, while I agree with the http://www.foxnews.com/story/0,2933,468084,00.html" article that blaming everything on CO2 is "silly", it is guilty of committing a similar crime when it quotes,
"Take a glass, put some ice in it. Put water in it. Mark level where water is. Let it met. After the ice melts, the sea level didn't go up in your glass of water. It's called the Archimedes Principle."
I think the bottom line is, humanity impacts the Earth's environment in many complicated ways, and we are possibly entering a new geological period based on human domination. I just hope we get to keep our freedom in coming years, and I hope we can spread that freedom to the many other people around the world who desperately need it.
I think advances in neuroscience and physics will have a far more dramatic effect on "us" and the planet than climate scientists are currently considering, which is part of why I've joined this site - so if you can point me in the direction of some good discussion on quantum / string / m theories, or neuroscience, I'd be most grateful! :smile:
Matt.
  • #145
Specifically the AP reporter talks in terms of "Arctic ice". I'm merely pointing out that the Greenland Ice sheet would qualify as Arctic ice according to the CIA World Fact Book:
https://www.cia.gov/library/publications/the-world-factbook/reference_maps/arctic.html
I'd say it's fairly easy to confuse thinking about the ice cap of the Arctic Ocean with written material that might refer more generally to Arctic ice. Hence as far as the reporter goes I'm willing to suspect that whatever imprecision there is excusable. As to the Professor at FSU, relied upon by Fox, I would be less forgiving.
  • #146
It might be confusing had the AP story not specifically referred to "summer Arctic sea ice" and again as "artic waters"
http://www.breitbart.com/article.php?id=D952LKOO1&show_article=1. Edit: Also, for even the worse case melt rate of the Greenland ice cap in the IPCC report, Greenland doesn't matter much for sea level rise. The worse case is ~0.5mm/year sea level rise (due to Greenland.) It certainly doesn't justify 'ominous' as used in the AP report.
  • #147
As I said I would excuse a reporter for careless references confusing Arctic ice and Arctic sea ice. The reporter may not clearly understand the distinction as evidenced by the explanation, but that doesn't invalidate the conclusion that Arctic ice melt outflows are contributing to Sea level rises. Nor is it apparently incorrect to say that this run off is accelerating.
But you'd think a Professor from FSU would be a little more careful and knowledgeable about Arctic ice and not be so rambunctious to be quoted by a partisan network like Fox, fueling partisan debate, by offering 4th grade science lessons, when his 4th grade geography is apparently so lacking. I'd think that guy would be embarrassed for offering up that explanation, and being quoted within that context.
As to the Greenland sheet I think there is an additional factor to just the run off in that its weight is compressing the land mass and the plate in the region and as its water mass flows into the oceans the upward thrust from the removed mass may also cause additional outflow from the waters around Greenland as the sea bed rises with the ground mass.
  • #148
But as land mass rises out of the sea, the sea level drops. DO NOT ask me what the imact is. :devil: I had discussed rising land mass in another thread having to do with the last major Ice Age. I'm sure the offset is negligible, and it also doesn't happen quickly. New York's Central Park is quite fascinating for studying the glaciers that were once there.
  • #149
Locally to Greenland this is true. I'd think it might tend to cancel out to a small extent - maybe even a very small extent - the rise.
But keep in mind that the local rise in sea bed around Greenland - the Earth being plastic will deform non-uniformly wouldn't you think and will displace sea water to the rest of world oceans in addition to the melt water off the landmass.
  • #150
Using this logic, wouldn't the increased mass of the ocean force all land masses up as the sea sinks?
  • #151
Yes, and the water will run off at a much faster rate than the land will rise, and I would assume that the impact of the eventual rise of land will be a negligible impact. What a lot of people don't realize is that while sea level rises in some places, it drops in others, there is no uniform worldwide rise or fall of sea level. Land can be breached and water spill over and create vast inland seas and lakes. I don't believe there are any projections for this happening just from Greenland ice melt, now you're going to make me try to find the maps of proposed scenarios, or you could be forever dear to my heart and find them for me. I find it a very interesting topic.
I feel rather safe here in Kansas.
  • #152
No, the land that was covered by ice will rise as the weight of the ice is removed. The sea isn't sinking.
  • #153
Why? If you were compressing the globe uniformly by the added melt - spread out over the surface of the oceans what actual net force do you figure can really be affected?
The Greenland Ice Sheet I'd think is more analogous to pressing a balloon at one point and affecting locally a plastic deformation from true round. Whatever resiliency of the crust to tend back toward a sphere when the ice mass melts you'd think would affect some change more locally to Greenland and the surrounding sea bed, and not so generally to pushing all land masses skyward.
  • #154
I really don't know but just thinking of moving mass from A (land) to B (ocean) that there would be an impact on the ocean floor depth though not as significant as sea level rise. Interesting that the land actually rises when the ice is removed. How much rise has been observed?
  • #155
The spill at the Bosporus into the Black Sea and the cataract there would have been a truly wondrous sight while it lasted. And who knows, speaking highly speculatively, but maybe at Gibraltar into the Mediterranean before it at some point.
  • #156
since the amount of water the atmosphere can hold increases with temperature, does anyone know how much of this melt water would end up in the atmosphere? and with more in the atmosphere, you'd expect more precipitation, increasing the amount of water stored on land. surely it can't all be allocated to rising sea levels.
  • #157
I think that's a complicated issue about how much additional water would be airborne or residing in lakes and streams. My sense of it is that it would be swamped by the amount of additional water melted.
Wikipedia said:
The Greenland Ice Sheet is a vast body of ice covering 1.71 million km², roughly 80% of the surface of Greenland. It is the second largest ice body in the World, after the Antarctic Ice Sheet. The ice sheet is almost 2,400 kilometers long in a north-south direction, and its greatest width is 1,100 kilometers at a latitude of 77° N, near its northern margin. The mean altitude of the ice is 2,135 meters. The thickness is generally more than 2 km (see picture) and over 3 km at its thickest point. It is not the only ice mass of Greenland - isolated glaciers and small ice caps cover between 76,000 and 100,000 square kilometers around the periphery. Some scientists believe that global warming may be about to push the ice sheet over a threshold where the entire ice sheet will melt in less than a few hundred years. If the entire 2.85 million km³ of ice were to melt, it would lead to a global sea level rise of 7.2 m (23.6 ft).
http://en.wikipedia.org/wiki/Greenland_Ice_Sheet
That's a lot of ice.
Interestingly some of the ice is held on Greenland below sea level - up to 300m below. If all the water melts there Greenland may become an archipelago. But before anyone gets all 4th grader with ice cubes in a glass analogies, there's still roughly 2 km of ice above sea level.
  • #158
But just think, if all of the ice melts, we will return to a lush, forested, green, healthy earth, as in the past. It's really not bad for the planet. People living on the coastlines might not be too happy. New species will flourish, as they did during those cycles in the past.
What I dislike about the hype is that so many people think the Earth is being destroyed. :rolleyes: I dislike deception for any reason, no matter how good some people's intentions are. Ask just about any young school age child and they will tell you that global warming means the world will end. A co-worker's wife is a science teacher at a local middle school and the things these kids believe to be true is appalling.
What we should be focused on is that we are running out of fossil fuels and we need to find alternative sources, and preferably sources that don't cause more pollution, or destroy more resources.
  • #159
also, it will take that ice a long time to melt. in the meantime, we people will just keep on doing what we're doing, fighting back nature. it's not like we've conquered it. we'll just make a gradual migration to wherever the conditions are better.
  • #160
We've been doing it for thousands of years and will be for thousands more. I think we could use a little more of a tropical climate anyway. Also, with all this ice gone, we will have more fertile land to habitate and farm. I see it as a win-win.
  • #161
I don't entirely disagree. Evolution has brought us to this point in time through waves of selection and cycles Shiva and Vishnu. And surely we worry about a lot of species going extinct, and maybe needlessly so, as we stand already on the bones of so many millions of species already.
My species extinction concerns are really more directed at the canary in the coal mine. That the environment is changing and how much of that is due to us. And of course is it possible that we may be unwittingly driving climate toward our own extinction, or nearly as bad, dramatic population reduction - at great misery no doubt - to life on a considerably more environmentally hostile planet.
And yes environmentally clean and renewable is the greatest heritage we can likely leave those that follow us.
  • #162
Yeah, and this is where my misanthropic side shows. :redface: It may not be pleasant to humans, if the worst case scenarious come true, but I'm not convinced that will be the case. I tend to take a bit of each side with a grain of salt. Two extreme agendas, the truth lies somewhere in between.
  • #163
I totally agree. I get a chill up my spine when I observe how some people consider AGW dogma. And they're scientists, no less.
  • #164
I don't know how this will change things, but I don't think people living near the equator want a warmer climate.
What do you think is going to happen to this ice? It doesn't just disappear, it turns into water. Higher sea levels = less habitable land. How much of a return we get on ice melted vs. coast lost I can't say, but it's definitely not a 100% win.
  • #165
Evo said:
...What I dislike about the hype is that so many people think the Earth is being destroyed. :rolleyes: I dislike deception for any reason, no matter how good some people's intentions are. Ask just about any young school age child and they will tell you that global warming means the world will end. A co-worker's wife is a science teacher at a local middle school and the things these kids believe to be true is appalling.
nice post, +1 :-p
  • #166
In addition to Evo's excellent wrap up, as discussed here, here, and especially here, there is no certainty whatsoever that more or less greenhouse gas is going to change anything about climate, especially given that large climate changes happened without clear relevance to greenhouse gasses. I mean, we must do the right things for the right reasons and the right thing is to reach a sustainable balance between nature and society, without worrying about the things that either don't matter or that we can't control and there is no way to control climate.
Therefore the stop-burning-fuel-and-save-the-climate hype is most unfortunate and will bounce whenever reality catches up and proves otherwise. The real thing should be: stop-burning-fuel-and-convert-to-a-sustainable-society-balanced-with-nature. That ideal can never be overrun by harsh reality.
Meanwhile, people get into bitter fights over this because of not understanding each other
  • #167
That's not completely off when you think about it. Imagine a baloon filled with the air. When you press the baloon at some place, baloon surface in other places goes up, to keep constant internal volume. That's to some extent similar situation. When the sea gets deeper it puts more pressure on the bottom, building additional pressure that may push land masses up.
We are probably talking about effect measured in centimeters, but it can still work to some extent.
  • #168
When I imagine all political and social tensions connected with the relocation of people from parts of the globe (like Africa) to other parts of the globe (Siberia?) I think it is a lose-lose.
  • #169
G01 said:
Interesting, but I don't think this sheds any light on the truth behind global warming.
In my opinion, both sides of the global warming debate have become so politicized that neither can be trusted.
What would this tell you about actuality? But you think the muddy waters begins with politics. It begins with fraudulent science--data padding, model selection, peer pressure, vatican (authoritarian) science, and better.
I remember postmodernism, progressivism, revisionism, relativism, Alan Sokal and The Science Wars. They didn't go away; they sulked a bit and invented new causes.
  • #170
Yes though the Earth balloon is crusty here, fluid over there. The crusty part does seem to rise up and down too, though usually some orders of magnitude slower than the ocean part of the Earth balloon, this difference in rate apparently allowing the http://www.awi.de/typo3temp/pics/91b26f7eef.jpg" , 3-4x times the worst case sea level rise associated with the melting of Greenland's ice sheet.
  • #171
mheslep said:
An exception: the http://news.nationalgeographic.com/news/2008/06/080605-andes-mountains.html", 3-4x times the worst case sea level rise associated with the melting of Greenland's ice sheet.
But I think that's an upthrust at a subduction zone at the South American plate boundary and an oceanic plate. It was likely accompanied by some rather dramatic quakes and slips as it piled up. Plates just have a different gear than water melt.
  • #172
LowlyPion said:
... Plates just have a different gear than water melt.
Yes, as I said.
  • #173
I really don't think we are running out of oil:
http://eteam.ncpa.org/commentaries/we-are-not-running-out-of-oil
...These estimates do not include unconventional oil resources that require additional processing to extract liquid petroleum. Oil production from tar sands in Canada and South America would add about 600 billion barrels to the world’s supply and rocks found in the three western states of Colorado, Utah and Wyoming alone contain 1,500 billion barrels of oil. Worldwide, the oil-shale reserves could be as large as 14,000 billion barrels — more than 500 years of oil supply at year 2000 production rates.
It is true that in the long run, an economy that utilizes petroleum as a primary energy source is not sustainable. However, sustainability is a chimera. Every technology since the birth of civilization has been replaced as people devised better and more efficient technologies. The history of energy use is largely one of substitution. From wood and whale oil in the 19th century, to coal by the 1890s. Coal remained the world’s largest source of energy until the 1960s. ...
And according to Peter Huber, author of The bottomless well, the tar sands in Alberta Canada alone have enough oil supply to provide the rest of the planet for over the next course of 100 years.
http://abcnews.go.com/2020/Stossel/story?id=1954572
  • #174
I think that is probably correct; just as the stone age did not end because of stone depletion, the oil age will not end because the last drop of oil has been pumped. The oil age will end because the cost of oil based energy is bound to increase as the easy to get oil depletes. For instance, these other sources mentioned above - sand, shale - require additional energy to break the oil free from the minerals containing it. Then, since the cost must be high, continuing to use oil as we have means straining the wallet and all the while supporting what would otherwise be failed petro states. Second, though I am far from convinced that the science of global warming is at the point where its predictions command immediate action, the world is none the less burning up one cubic mile of oil every year and releasing the combustion products into the atmosphere. That to my mind warrants caution, so that I favor using alternatives any time they are economically viable.
Edit: EIA shows world oil production has been hovering at 84 to 85 m bbl / day for the last 4-5 years. T. Boone says he expects it to stay there.
http://tonto.eia.doe.gov/cfapps/STEO_Query/steotables.cfm?tableNumber=6&periodType=Annual&startYear=1994&startMonth=1&startMonthChanged=false&startQuarter=1&startQuarterChanged=false&endYear=2009&endMonth=12&endMonthChanged=false&endQuarter=4&endQuarterChanged=false&noScroll=false&loadAction=Apply+Changes
  • #175
There are relatively few scientists that dispute AGW.
The most prominent Lindzen, Spencer. and Pielke all accept the view that CO2 is contributing to a warming trend.
46K
25K
