PAllen
- 2,558
PeterDonis said:Not if the simultaneity convention can be realized by a physical procedure, as Einstein simultaneity can. That convention does not assume isotropy; the fact that, when an inertial observer adopts this convention, he finds that his coordinates have spatial isotropy, is a physical fact about his state of motion and the physical procedure he uses to realize the simultaneity convention (i.e., the procedure used for Einstein clock synchronization).
Not sure what you are getting at - Einstein simultaneity convention explicitly assumes isotropy of one way speed of light (or defines it that way). [The factor of 1/2, and that you do the same in all directions, are explicit assumptions of isotropy. They make no sense without such an assumption.] On the other hand, if you assume anisotropy of the Edward's frame variety, you use a derive from this assumption that a different synchronization should be used, and you then 'confirm' that both one way light speed and the laws of mechanics are anisotropic - and consistent with experiment if this regime is carried out properly.
What I think is non-trivial, and makes it pedantic to really argue that there is nothing to isotropy, is that if you define coordinates to achieve isotropy for anyone phenomenon, you find it holds for all others. But the pedant can certainly say you have not ruled out anisotropy of just the right kind, coordinated in just the right way for all phenomena.
My point remains that I think the physical definition of isotropy should be that all laws display isotropy in the same group of frames/coordinates. If we find this, we say the universe is isotropic - by definition. Then we can say SR combined with EM and mechanics is isotropic - in the sense we have defined isotropic.
