- #141
PeterDonis
Mentor
- 47,662
- 23,919
loislane said:You seem to be using the word observer as if it was something physical instead of a mathematical abstraction
Exactly. An "observer" as I'm using the term is a physical thing that can carry an accelerometer and observe and record its readings. It's certainly not a mathematical abstraction. You and I can be observers.
loislane said:apparently a distinction can be made between an inertial observer and an inertial frame
Yes, certainly. A physical thing that can carry an accelerometer has some physical reading on its accelerometer, independent of how we describe the thing and its motion mathematically. Without such a distinction, our physical theories would have no meaning, because we would have no way of linking them up with actual observations.
loislane said:What if we make the distinction between an observer at rest in the rindler coordinates, that is noninertial because it has to accelerate to counter the "acceleration" of the curvilinear coordinates, and an observer following the hyperbolic motion
These two are the same. An observer at rest in Rindler coordinates is non-inertial, and is following hyperbolic motion in Minkowski coordinates.
loislane said:a Minkowski observer in Rindler coordinates, is it inertial or noninertial?
If you mean an observer at rest in Minkowski coordinates, such an observer is inertial. This observer won't be at rest in Rindler coordinates, but that is irrelevant to the question of whether the observer (as opposed to the coordinates) is inertial or not.
loislane said:I think there is a problem with observers and frames as objects with motion, so it is best to stick to coordinates. If a frame or observer is something physical rather than an abstract labeling the conclusions derived from them are different.
I'm not sure why you would think this. The fact that observers are physical things doesn't mean we can't describe them mathematically. One way is to describe observers by the worldlines they follow; then we can write equations for those worldlines in different coordinate charts. Another way is to describe observers by frame fields (mappings of sets of orthonormal basis vectors to points in spacetime). I don't see that mathematically modeling observers poses any particular problem; it just requires a clear understanding of what you're trying to model.
