jbriggs444
2024 Award
- 13,334
- 8,010
A tetrahedron (three equilateral triangles meeting at the north pole) stuck to a second tetrahedron (three equilateral triangles meeting at the south pole) does not make a figure that can be inscribed within a sphere. An octahedron (four triangles meeting at the poles to make two four-sided pyramids joined square face to square face at the equator will work).Chris Miller said:Doh! Of course! Why didn't I see that? Six equilateral triangles with apexes at either pole meeting at the equator. Not a sphere, but the more you subdivide them into smaller equilateral triangles the closer you can approximate (adhere to) a sphere.
But you already realize this.
Dividing each face into smaller equilateral triangles does nothing to unflatten those faces. You still need to unflatten them up against the surface of the sphere.
Those of us who played DnD in our youth have a firm picture of the regular polyhedra. The six sided regular polyhedron has squares for faces, not triangles. It is called a "cube".
For any local region, you can pretend that the region is flat. But pretending does not make it so. The global topology does not change just because you can flatten out any particular region by distorting it a little. The little distortions build up. Eventually the paper tears. Or wrinkles. Or both.So maybe there is a way to tile the hypercube with small regions of locally flat spacetime?
It is not that there is any ambiguity about the answer to a properly posed question. It is that the question, as posed, is ambiguous -- and pretends that it is not.Chris Miller said:gives off an undecidedness vibe
