- #491
- 11,714
- 1,985
Intro to alg geom 2
II. NEW METHODS FOR PLANE CURVES: TOPOLOGY and COMPLEX ANALYSIS
Riemann associated to a plane curve f(X,Y)=0 its set of complex solutions, compactified and desingularized. This is its "Riemann surface", a real topological 2 manifold with a complex structure obtained by a branched projection onto the complex line. For instance the curve y^2 = 1-X^3 becomes its own Riemann surface after adding one point at infinity, making it a topological torus. Projection on the X coordinate is a 2:1 cover of the extended X line, branched over infinity and the solutions of 1-X^3 = 0.
This association is a functor, i.e. a non constant rational map of plane curves yields an associated holomorphic map of their Riemann surfaces, in particular a topological branched cover. Riemann assigns to a real 2 manifold its "genus" (the number of handles), and calculates that branched covers cannot raise genus, and the only surface of genus zero is the sphere = the Riemann surface of the complex t line. Hence if the Riemann surface of a plane curve has positive genus, it cannot be the branched image of the sphere, hence the curve cannot be parametrized by the coordinate t.
Riemann also proved a smooth plane curve of degree d has genus g = (d-1)(d-2)/2, so smooth cubics and higher degree curves all have positive genus and hence cannot be parametrized. He proved conversely that any curve whose Riemann surface has genus zero can be parametrized, e.g. hyperbolas, circles, lines, parabolas, ellipses, or any curve of degree < 3. Moreover a singularity, i.e. a point where the curve has no tangent line, like (0,0) on Y^2 = X^3, lowers the genus during the desingularization process, and this is why such a "singular" cubic can be parametrized.
One also obtains a criterion for any two irreducible plane curves to be rationally isomorphic, namely their Riemann surfaces should be not just topologically, but holomorphically isomorphic. By representing a smooth plane cubic as a quotient of the complex line C by a lattice, using the Weierstrass P function, one can prove that many complex tori are not holomorphically equivalent, by studying the induced map of lattices. It follows that there is a one parameter family of smooth plane cubics which are rationally distinct from each other.
This shows briefly the power and flexibility of topological and holomorphic methods, which Riemann largely invented for this purpose, an amazing illustration of thinking outside traditional confines.
