Show that the radius of the exoplanet is about 1/2 of Earth’s radius
The discussion centers on calculating the radius of a transiting exoplanet, which is approximately half that of Earth's radius, based on its orbital radial velocity of 17 m/s. The equation used is 2Rexo = Vexo(t1 - t2), where t1 and t2 represent the times of maximum and minimum brightness, respectively. Clarification is provided that t1 is the time of minimum brightness and t2 is when brightness was last maximized, with the total duration from maximum to minimum being 4.3 days. There is confusion regarding whether to use the total transit time directly in the equation. Understanding the symbols and the derivation of the formula is emphasized as crucial for accurate calculations.
hraghav
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: For a transiting exoplanet, we find it takes 4.3 days from the start of the transit for the host star to reach a minimum brightness, which lasts for 10 days. Show that the radius of the exoplanet is about 1/2 of Earth’s radius if its orbital radial velocity is 17 m/s.
I am trying to use the equation 2Rexo = Vexo(t1 -t2) where Vexo = 17 m/s and I need to find the Radius of the exoplanet and then convert it to Earth radii where I should get my final answer as 0.5R⊕. But I am confused with the values of t1 and t2? What should they be? Could I simply just use T= 4.3 days instead of t1 and t2 ie 2Rexo = Vexo*T? I am really confused with this and it would be great if someone could please help me out with this. Thank you!
It is not much use having a formula if you do not know what the symbols mean.
In the present case, it would appear that ##t_1## is the time at which the brightness becomes minimised and ##t_2## is the time at which it was last maximised. I.e., ##t_1-t_2## is the time to go from maximum brightness to minimum, 4.3 days.
… and arguably also why the formula has the structure it has. Much more than memorizing formulas, a deeper understanding of physics requires not only knowing lots of formulas, but understanding how they arise and being able to derive them.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
