Sign of Work (Negative or Positive)
  • Thread starter Thread starter Ineedhelpwithphysics
    Force Motion Work
The discussion centers on the confusion surrounding the calculation of work done by a pump lifting water. The calculation of work done by the pump is positive because both the force exerted by the pump and the displacement of the water are in the same direction. In contrast, gravity does negative work on the water as it opposes the upward motion. The net work done on the water is the sum of the positive work from the pump and the negative work from gravity. Clarifying which specific work is being calculated is essential for accurate interpretation.
A pump is required to lift 850 kg
of water per minute from a well 14.7 m
deep and eject it with a speed of 17.7 m/s
W = F*d
W = delta KE
Im confused I did
850*9.8*14.7 = 1.2x10^5
Why is it not negative since the force is opposite to the motion?
The force that the pump exerts on the water is upward, and the motion is upward.
What exactly is the question as was given to you? Which work are you trying to calculate? When calculating work you have to specify the force that does the work and the system on which this work is done.
Assuming that the system is the water, the pump does positive work on the water as @Chestermiller explained but gravity does negative work on the water. In any case, in the work-energy theorem equation that you wrote down, W is the net work done on the water, that is the positive work done by the pump and the negative work done by gravity. You just calculated the work done by gravity with the wrong sign.
Ineedhelpwithphysics said:
Homework Statement: A pump is required to lift 850 kg
Relevant Equations: W = F*d
W = delta KE
Im confused I did
You can't get a negative number by multiplying positive numbers. Your equation represents force and displacement in the same direction. The force is positive and the displacement is positive.
Sign of what work? Always state the full question exactly as given. In this case it could be either the work done by the pump or the work done by gravity. If you don’t specify, we cannot know.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
