Simple Harmonic Motion Guitar String Question
The discussion revolves around calculating the maximum speed and acceleration of a guitar string's midpoint oscillating with a 2.24mm amplitude and a frequency of 400Hz. The correct formula for maximum speed was applied, resulting in a value of 5.6 m/s. However, confusion arose regarding the maximum acceleration, with some participants misinterpreting the midpoint as the oscillation's midpoint rather than the physical midpoint of the string. It was clarified that the displacement at the midpoint should not be assumed to be zero, as it refers to the string's length rather than its oscillation position. Understanding the distinction between displacement and amplitude is crucial for accurate calculations.
Apothem
Question: "The midpoint of a guitar string oscillates with an amplitude of 2.24mm with a frequency of 400Hz. Calculate:
i) The maximum speed at this point
ii) The maximum acceleration of the string at this point"
Suitable formulas: x=Asin(2*pi*f*t) ; a=-(2*pi*f)2(x) ; v=(2*pi*f)(A)
where A= amplitude/m ; f=frequency/Hz ; t=time/s
Attempted Solution:
I think I am alright with part i) I did: v=(2*pi*400)*(2.24x10-3)=5.6ms-1
However for part ii) I am a bit unsure, do I take x to be the amplitude, but at the midpoint would x not be 0, so the acceleration is 0 ms-2?
(I originally posted this in the wrong section, and reposted it in the correct section, sorry if I should not have reposted it in a new section)
Your formulas under 2. are just for the displacement ##x## of a single point on the strong. There's no notion of the "midpoint" or any other point (think of the rest position of the point on the string as ##y##).
Sorry, I am unsure on what you mean. I understand your first point, just not about the midpoint.
Maybe I misunderstood what you posted earlier, but I think there is some confusion between the "midpoint" along the string (where x(t), v(t), and a(t) are given) and the "midpoint" of the oscillation (the rest position of the point, or where x=0).
Yes, clearly the question means midpoint along the length of the string. It does look like Apothem has misinterpreted it as midpoint of oscillation.
Apothem, x is not the amplitude, it is the displacement at time t. The amplitude is the maximum displacement.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
