Simple projectile motion question
ashclouded
A missle is fired vertically up from a ground with an initial velocity of 20m/s. The acceleration at any time is given by dv/dt = -10 + t/2 m/s^2.
Find the height of the missile after two seconds
Find the height after four seconds
the direction the missile is traveling when t = 4
Displacement = x
Velocity = dx/dt
acceleration = dv/dt
dx/dt = -10t + t^2/4 + c
found c to be 20
x = -5t + x^3/12 + 20t + c
when t = 0 displacement = 0
c = 0
-5t + x^3/12 + 20t
then I don't know what to do
Displacement = x
Velocity = dx/dt
found c to be 20
c = 0
-5t + x^3/12 + 20t
You've managed to mangle your calculus here, which is why you get confused.
According to the OP, dv/dt = -10 + t/2 m/s2
If you separate the variables and integrate, you get
∫ dv = ∫ (t/2 - 10) dt, or
v = t2/4 - 10t + C m/s
According to the OP, v @ t = 0 is equal to 20 m/s, so C = 20
But, v = dx/dt = t2/4 - 10t + 20, so separating variables and integrating again we get:
∫ dx = ∫ [ t2/4 - 10t + 20] dt which gives
which I'll leave you to work out. You should be able to answer the questions about the height of the rocket very easily.
Sorry about the multiple post, thanks for the help but
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
