Solve General Equation: ODE Project
  • Thread starter Thread starter trajan22
    Ode Project
trajan22
Im sorry, I posted this in the wrong section, feel free to move it to the homework section.
Hey guys, I've really been needing some help with this one. I am doing an assignment for Ordinary Differential Equations and I was hoping someone could help me out by looking over my work. I've been working on this assignment for a couple of weeks now and finally decided that I just needed help.
There is a second part of this problem, but Ill post that later depending on whether or not this part is correct.
Anyway, I know this is a really long post but I will truly appreciate the help of anyone that's willing to go through it all.
Basically I just need to solve the general equation below for different values of gamma and lambda.
Thanks
<br /> General Equation<br />
<br /> \frac {dm}{dt}=-\alpha m^{\gamma}-\lambda m<br />
<br /> \lambda = constant
<br /> Case (1)<br />
\gamma=1
1a.) \frac{dm}{dt}=-\alpha(m)-\lambda(m)
2a.) \frac{dm}{dt}=-m(\alpha+\lambda)
3a.) \int \frac{1}{m}dm=\int (\alpha+\lambda)dt
4a.) \ln(m)=-(\alpha+\lambda)t+C
5a.) m=e^{-(\alpha+\lambda)t+C}
Case (2)
constraints
\gamma cannot =0 \lambda=0
Simplifying the general equation I get
1b.) \frac{dm}{dt}= -\alpha (m)^\gamma
2b.) \int \frac{1}{m^\gamma}dm=-\int \alpha dt
3b.) \frac{m^{(-\gamma + 1)}}{-\gamma+1}=-\alpha (t)+C
4b.) m=[(-\alpha (t)+C)(-\gamma+1)]^{1/(-\gamma+1)}
Case (3)
Constraints
\gamma not=1 \lambda not =01c.) \frac{dm}{dt}=-\alpha (m^{\gamma)}-\lambda (m)
I then solved this using the Bernoulli method
2c.) v\equiv m^{(1-\gamma)} for \gamma cannot =1
3c.) \frac{dv}{dt}=(1-\gamma)m^{(-\gamma)} \frac{dm}{dt}
4c.) \frac{dm}{dt}+\lambda (m) =-\alpha (m^{\gamma)}
5c.) m^{(-\gamma)}\frac{dm}{dt}=-\alpha-\lambda m^{(1-\gamma)}
6c.) m^{(-\gamma)} \frac{dm}{dt}=-\alpha-\lambda (v)
Substituting dv/dt into the equation I get
7c.) \frac{dv}{dt}=(1-\gamma) m^{-\gamma} m^{\gamma}(-\alpha-\lambda v)
8c.) \frac{dv}{dt}=(1-\gamma)(-\alpha-\lambda v)
9c.) \frac{dv}{dt}+(1-\gamma)(\lambda)(v)= -(1-\gamma)\alpha
This is a linear first order homogeneous equation and can be solved by making
10c.) \mu=e^{\int(1-\gamma)\lambda dt} =e^{(1-\gamma)\lambda(t)}
using this as my integrating factor I get this
11c.) v=\frac{1}{e^{(1-\gamma(t)}}\int e^{(1-\gamma)t} (1-\gamma) (-\alpha)dt
this yields
12c.) v=-\alpha +\frac{C}{e^{((1-\gamma)t)}}
substituting for v we get
13c.) m=(-\alpha+ \frac{C}{e^{((1-\gamma)t))}}^{(\frac{1}{1-\gamma})}<br /> <br />
Am I doing anything wrong?
You don't seem to be doing anything wrong. Another approach to the last case could be to take \alpha m^{\gamma -1}+\lambda =u
This gives \alpha (\gamma -1) \frac{m^{\gamma -1}}{m}dm=du
\frac{dm}{m}=\frac{dt}{\alpha m^{\gamma -1}{\gamma -1}}
Substituting this in equation 1c. you get \frac{du}{(\gamma -1)u-\lambda}=-dt
Integrating this, you get ln(\alpha m^{\gamma -1})=-(\gamma -1)t +C.
Isolating m, I suspect you would get the same answer, but this method is a lot simpler...
Thanks for looking it over. Your right that is a much easier method.
But in the second part of the question it states "show that when \gamma \geq 1 then the source must have an infinite lifetime.
The way I took this is that if it is to have an infinite life then the \lim _{t \rightarrow \infty}m=\infty
However when I actually do this I get that the source approaches zero.
Am I simply misunderstanding the question?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
