Solve the homogeneous ODE: dy/dx = (x^2 + y^2)/xy
  • Thread starter Thread starter chwala
    Homogeneous Ode
chwala
kindly see attached below:
##y=vx##
this is pretty easy for me to solve, no doubt on that. My question is on the constant. Alternatively, is it correct to have,
##ln x= \frac {v^2}{2}##+ C, then work it from there...
secondly, we are 'making" ##c= ln k##, is it for convenience purposes?, supposing i left the constant as it is, would that be wrong?
##ln x-c= \frac {v^2}{2}##
##2[ln x-c]=v^2##
##2x^2[ln x-c]=y^2## would this be correct?...the question that i am trying to ask is, does it matter where one places the constant after integration.
No it doesn't matter where you put the constant neither if you set it equal to ##\ln k## or ##\ln \frac{1}{k}##, because given an initial condition you will get the same formula for v in both cases, but the exact value of the constants will be different (for example if you find k=2 for the one case, you ll find k=1/2 for the other case).
nice delta :cool:
My personal preference is to insert the initial conditions explicitly by doing definite integrals
$$\int_{v_0}^v v~dv=\int_{x_0}^x \frac{1}{x}~dx$$ $$\frac{1}{2}\left(v^2-v_0^2\right)=\ln\left(\frac{x}{x_0}\right) \implies v=\pm \sqrt{ 2\left[v_0^2+ \ln\left(\frac{x}{x_0}\right)\right]}.$$If the equation is related to a physics problem, this method takes care of the dimensions automatically.
Likes Charles Link and chwala
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
