Solving for Time Given Acceleration & Initial Velocity
To solve for time given acceleration and initial velocity, it's essential to recognize that knowing only acceleration is insufficient for determining displacement. The discussion emphasizes the need for additional information, such as final velocity or time, to utilize the relevant equations effectively. Clarifying the question would help focus on which equations relate displacement to acceleration and other variables. The conversation highlights that displacement can be expressed in terms of initial velocity, current velocity, and time. Ultimately, understanding the relationships between these variables is crucial for solving the problem accurately.
kara123
Which equation would you use to determine the displacement of an object moving with uniform acceleration given a value for acceleration?
a. ∆d=vi∆t+(aav(∆t)^2)/2
b. Vf=Vi+aav∆t
c. ∆d=[(vf+vi)/2]∆t
d. vf^2 =vi^2+(2aav∆d)
assuming initial velocity is 0 and we have the value for acceleration I'm unsure how to still use any of those equations because you must have a time value at least or a final velocity
You are thinking correctly. If the value of the acceleration is the only thing that you know, there is no way to determine the displacement.
Although I agree with your assessment, I don't think that the author of the question meant to imply that the acceleration is the only given quantity. This looks like a question where one needs to show an understanding of what the equations say. Of the four choices, only two are expressions for displacement. Of these, only one has acceleration on the right-hand side.
A clearer statement of the question might have been
Which equation would you use to determine the displacement of an object moving with uniform acceleration if one of the given quantities is the value of the acceleration?
You would still have the choice of expressing the displacement as a function of any two of initial velocity, current velocity and time.
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
