Solving for Work Done When Accelerating a Mass
The discussion focuses on calculating work done on an object with an initial velocity of 0 m/s, mass of 8.4 kg, traveling 0.495 m in 0.1625 seconds. The acceleration is calculated to be 37.495 m/s², leading to a final velocity of 6.09375 m/s. The work done is computed as 155.925 joules, assuming constant acceleration. Participants emphasize the importance of significant figures in reporting results and suggest algebraic methods for improved accuracy and clarity. The conversation also notes that varying the acceleration pattern could reduce the work required for the same motion.
Jay529
Need help checking my work and appropriate use of equations.
acceleration: s=ut + 1/2 ut^2, final velocity: V= u+at, work done: W=1/2 mv^2
I wanted to make sure these were the correct equations to use for they were not given. I had to research to get this far and only had the below statement to go off.
The problem is an object with initial velocity = "0." It travels 0.495m in 0.1625sec and weights 8.4 kg
or
Initial velocity (u) = 0 m/s, Mass (m) = 8.4 kg, Distance (s) = 0.495 m, Time (t) = 0.1625
Solving for acceleration: 0.495 = 0 + 1/2 * a (0.1625)^2
a= (2*0.495)/ 0.1625^2 = 37.495m/sec^2
Now that I have acceleration
Calculate final velocity: V= 37.495 * .01625 = 6.09375m/s
Solving for Work done: W=1/2 * 8.4 * 6.09375^2 = .5 * 8.4 * 37.125 = 155.925 joules
You are assuming constant acceleration. Is that given?
Yes, I believe.
Jay529 said:
Yes, I believe.
Then I get the same result to four significant figures. The mass is only given to two significant figures, so really that is all you can give in the answer.
Had you worked algebraically you would have got some cancellation: ##2m(\frac st)^2##. That allows you to check that the result is dimensionally correct and can improve accuracy. It has many other advantages. It is certainly easier for others to follow.
Btw, if the acceleration pattern can be anything you choose, the motion can be achieved using a quarter of the work.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
