Solving Torsion Spring Problem with 100 lb Force
The discussion revolves around determining the appropriate spring rate for a torsion spring that supports a tire subjected to a downward force of 100 lbs without deflection. It emphasizes the necessity of having a pretensioned spring and an end stop to prevent any deflection under load. The calculation involves determining the required torque based on the force and the horizontal distance from the tire to the spring center. Once the torque value is established, suitable springs can be sourced from catalogs. Understanding the spring rate is crucial when there are specific force and angle of rotation requirements in the design.
bpaliwal
I am struggling through a problem in one of my designs and would appreciate some help.
Please refer to the image attached.
Problem Description:
S = Torsion spring
F = fixed point
T = tire
A tire is attached to a torsion spring through an arm as shown in the image. The torsion spring has one end connected to a fixed wall and the other connected to the arm S-T at point F.
How much spring rate (lbs-in/degree) should be there on the spring S, so that the tire T is subjected to a force of 100lbs in the downward direction before any deflection occurs in the spring?
Also, I forgot to mention in the image the angle of S-T with the horizontal is 33.127 degrees.
Any help would be appreciated.
246091
If you want the tire to be able to be subject to 100lb of force before there is any deflection, you need the mechanism to be against an end stop and the spring subject to pretension. If you don't have an end stop and a pre-tensioned spring, there is no spring rate you can chose to achieve this - no matter what the rate is, you will always see some deflection at any force level.
Likes bpaliwal
Thanks for the response.
I am working on the pretension design for the spring. All I am concerned about is how much spring rate do I need?
Considering everything is weightless, will it be just the 100lbs force multiplied by the horizontal distance between the tire and the spring center? Regards
For what you have shown you would be calculating the required torque of the spring. Once you have that value, then it is just a matter of going to catalogs to find an appropriate spring that will supply that torque.
Spring rate for an application is only a factor when there two required forces and required angle of rotation for the spring between those two forces.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
