sophiecentaur
- 30,121
- 7,391
3% is an amazingly high rate. Who (in their right mind - certainly not a PF member) would ever volunteer for any other activity with such a risk of death? The total actual number is small because there are so few participants. It's more risky than pretty much any other activity I can think of - apart from Russian Roulette. Base jumping, by comparison, is a stroll in the park.mfb said:~3% fatality rate for astronauts, not from in-orbit operation but from launches and landings.
The perception of risk is so dependent on subjective factors and the way the statistics are stated. The number of millions of miles is not a meaningful measure for any activity. People travel no miles at all when they are struck by falling objects on building sites and that is a very common form of accident.
I am not "obsessing" at all. I have already said that I accept the proper objections to the system. What I am objecting to is the skewed arguments against it. The perceived risk of a serious collision is so overblown and you are not comparing like with like. If you want to discuss retro failure then you have to consider it for both cases. How far away does your visiting ship need to be from a Massive space station before you can be sure of avoiding a collision due to thruster failure? How many minutes / hours away from docking does that represent? On the grounds of collision cross section area alone, a station that's ten times the cross section of the ISS would need ten times the docking time. Otoh, a tangential approach would reduce the consequences of a slight mis-registration because the closing speed could be less; the approaching ship would only need to deflect by a few metres to avoid a collision, compared with needing to veer off by the total radius of the station. All you have done is to apply existing 'rules' to the two possible future options. Is that reasonable? (Or not obsessional)A.T. said:You are obsessing about a non-issue.
